tuning standard erst engine
Old Feb 21, 2006 | 07:10 PM
nick8saff's Avatar
nick8saff
Default tuning standard erst engine
just brought a rs and wanted to no whats the best thing to do 2 make it a bit faster but safe.cheers
Old Feb 21, 2006 | 07:12 PM
teamfatboy's Avatar
teamfatboy
Frog Tosser
exhaust, filter amd chip me thinks
Dominic
Old Feb 21, 2006 | 07:25 PM
dave_y's Avatar
dave_y
and intercooler
Old Feb 21, 2006 | 08:55 PM
rst230bhp's Avatar
rst230bhp
and brakes
Old Feb 21, 2006 | 10:51 PM
petermintrst's Avatar
petermintrst
and a payrise to afford the petrol after the chip
Old Feb 22, 2006 | 08:59 AM
ivorbiggun's Avatar
ivorbiggun
Exhaust and filter will make BUGGER all difference to a standard car's performance/but at least you'll help 'someone' with this months mortgage payments.... Chip off ebay or one of the classifieds (about Ł40) 31 actuator
(about the same) and a trip to Jamie at Jamsport (Ł125) should see you
knocking on the door of 185bhp.
Then, 2wd Cosie discs (Ł50/60 anywhere) and brackets to resite your standard calipers (Ł40 from Clint Gaskin at Turbosport) goodridge hoses (Ł35 anywhere) and junk the standard 'abs' now you'll be able to stop (fairly important) as well as go.
Once your go above this it starts getting expensive/clutches+gearboxes etc
Good Luck
Old Feb 22, 2006 | 09:21 AM
thelynx's Avatar
thelynx
I had a turbosystems chipped ecu running 12psi and hit 168bhp/177ft/lb
Old Feb 22, 2006 | 09:55 AM
ivorbiggun's Avatar
ivorbiggun
The chip is fairly unimportant (only that it works) as all it does is remove the safety parameters and to allow more boost with out retarding the igniton which My Ford originally put in place to protect the engine/and his warranty department.
Jamie boosts to around 14psi which is generally the safe limit of a good
engine and usually the limit of the standard intercooler/hence around 180/185 brake.
Old Feb 22, 2006 | 11:29 AM
petermintrst
i'd love to chip mine but dont know what condition the engine is in so dont want it to go pop. no way afford to repair it
Old Feb 24, 2006 | 01:09 PM
AndyRST's Avatar
AndyRST
Dont forget that the RST chip also has a ignition curve for that type of engine written on it. And im told (if its true ) that different chips have different ignition curves to help mid range driveablity and reduce the chance of det when running higher boost levels
Old Feb 25, 2006 | 10:27 AM
jezRS's Avatar
jezRS
just buy a bayjoo chip, only one worth having, they are not that expensive
Old Feb 25, 2006 | 11:06 AM
swerv's Avatar
swerv
pmsl at people saying that chips don’t matter, what a load of bollocks!!
First off I wouldn’t buy a 2nd hand chip unless off a tuner who has one.
If you are tuning any car do not do it on a shoe string budget, you will come very unstuck
Personally, I would get a chip, something like a turbosystems chip will be a good one. You will have to get an uprated intercooler with the boost increase as well.
You must get the fuelling checked to make sure that the metering head is still up to the job after all these years.
Good luck
Old Feb 25, 2006 | 11:15 AM
a11ova's Avatar
a11ova
Filter, System (mongoose), Chip, -31 Actuator, Front mount and about 16-17psi
should see you close the 200mark.
then of course breaks and suspensions etc
big_Rad
Sep 15, 2017 09:36 AM
bigryrs
Mar 28, 2016 09:11 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
