Cam Removal
Old Feb 21, 2006 | 12:37 PM
S1 Barkham's Avatar
S1 Barkham
Default Cam Removal
Can you remove the cam out of a S2 without removing the head?
Also when running a new cam in do you hold it at 2-2.5k rpm for 20 mins? CheeRS
Old Feb 21, 2006 | 01:06 PM
Wazzzer's Avatar
Wazzzer
yes and yes
you need to undo all the rocker arms, take out all the tappets, remove the dizzy and pulley, take the thrust plate out from behind the pulley and slide it towards the dizzy end of the head, job done
If you're using new tappets make sure you soak them in oil for a couple of hours before fitting them
Old Feb 21, 2006 | 05:12 PM
G-Junior's Avatar
G-Junior
Cheers for askin that Barkham. Thanx for that I'll find something to soak them in.
A.t.p
Sep 29, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
grishenko45
Sep 9, 2015 12:58 PM
