How to check a coilpack?
Old Feb 20, 2006 | 02:37 PM
FAST AS FORD's Avatar
FAST AS FORD
Default How to check a coilpack?
How do i check if a coilpack is faulty? Its on my '95 golf vr6, i've noticed that its sparking were the leads connect, how do i check whether its the coilpack or the leads themselves?
Would the leads breaking down cause it to spark at the coilpack?
Any info would be great as im just about to buy a coilpack, but i m not 100% if its the leads?
Old Feb 20, 2006 | 03:02 PM
AlexF's Avatar
AlexF
2 ways...
measure the resistance of the low tension coils (primarys)
or
Measure the output voltage (Kv) of the high tension (secondarys).
Your best bet is probably to compair the resistances of the leads to each other (or a new one if you can get access to one). Then check the resistances of the coils and see what you find!
Alex
Old Feb 20, 2006 | 04:03 PM
FAST AS FORD
Cheers for that Alex
Old Feb 21, 2006 | 01:20 PM
FAST AS FORD
When i start the car it runs on 3 or 4 cylinders and sparks at 2 or 3 of the lead ends at the coilpack. When i accelerate it stops sparking and works fine. Does this indicate anything? Also, it usually stops once the car is warmed up.
Shall i buy some new lead?
Old Feb 21, 2006 | 02:39 PM
AlexF's Avatar
AlexF
when you say "sparks at 2 or 3 of the lead ends at the coilpack"
you mean there are visable sparks at the end of the HT leads where they meet the coil pack?
Alex
Old Feb 22, 2006 | 08:00 AM
FAST AS FORD
Yeah, thats it alex, what does this mean?
Old Feb 22, 2006 | 01:19 PM
AlexF's Avatar
AlexF
it means your HT leads are goosed!!!
problem found I hope!
The sparks should be at the plugs... not the conenction to the coil packs. The electricty is finding it easier to jump there than where it should do.
Alex
Old Feb 22, 2006 | 04:04 PM
FAST AS FORD
Spot on, thanks for that alex!, now i just have to find £100 for 6 new leads
Old Feb 22, 2006 | 04:10 PM
AlexF's Avatar
AlexF
you could try giving them a damn good clean in brake cleaner...
it *might* just be loads of dirt.
Alex
Old Feb 23, 2006 | 05:52 AM
FAST AS FORD
Cool, i'll give that a try, but the leads do look pretty old.
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
