help with MFI manifold pls ???
I'm putting together cossie management on my S2, i'm going to use the standard manifold which will need modifying to take the cossie injectors. I have a fiesta fuel rail just need someone to complete the mod for the injectors.
So who can do it ??? Does anyone know how much also ???
that i don't know. I guess you are referring to the impedemce. I'm sure there must be black boxes out there that can "convert" the impedence of an injector - always wondered this.
i've noticed on some RST's with cossie management that the original injector manifold (the small piece of manifold sandwiched between plenum and head) is not used , and 4 blocks are welded on and drilled out for the cossie injectors on the main manifold.
Would like to go this route !!
am actually gonna use a XR3i manifold, so i need to find someone to carry the mod out for me ????
And before everyone says it........... i don't care about flow, not looking for big power at all !! Just want cossie management coz it's neater and more reliable !!!!
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
caprixpack
Sep 25, 2015 07:53 PM
