Washer bottle
Old Feb 18, 2006 | 01:10 PM
Rippers's Avatar
Rippers
Monte Geek
Default Washer bottle
I noticed when fitting the engine undershield that my washer bottle wasn't very secure. In fact it was leaning down one side and had a lot of movement. I can't for the life of me work out how its fitted as I can't see any bolt/screw holes or mounts on it anywhere from above or below? Surely they don't just rest there
Anyone got any advise?
Old Feb 18, 2006 | 03:37 PM
filthyrichie's Avatar
filthyrichie
no more nails
Old Feb 18, 2006 | 03:50 PM
Dave Henshall's Avatar
Dave Henshall
u'll probably find one of the mouting lugs has snapped off (very common) i mad e anew ally bracked and revitted that into teh bottle with some epoxy resin underneath to seal the holes, you will find that in teh std location, one of the lugs is under a lot of strain (the one that snaps) I HAD TO ADD A SPACER (ABOUT 1/2") between teh lug and the shell to get it to sit nicely.
Old Feb 18, 2006 | 04:17 PM
dave cos4x4's Avatar
dave cos4x4
Paul,
thereis a strap that keeps it in place iirc.
not that secure.
Old Feb 18, 2006 | 06:04 PM
Dave Henshall
definately shouldn't be a strap, there are 3 mounting points... its the upper fornt one that is strained.
Old Feb 18, 2006 | 09:37 PM
Rippers's Avatar
Rippers
Monte Geek
Will spend some more time looking at it tomorrow
Old Feb 19, 2006 | 10:48 AM
Tandy's Avatar
Tandy
i think you have to take off the arch liner to get to 2 fixing points got same prob with mine might be worth taking it off just to check and have a clean up while your at it if you have microcat that will show you all the fixings cant get mine to work at the mo but im sure some kind soul will post up the layout. at the mo i just cant remember
Old Feb 19, 2006 | 11:08 AM
Rippers's Avatar
Rippers
Monte Geek
Tried microcat and like everything Cosworth it showed the base model washer bottle which is different
Old Feb 19, 2006 | 02:32 PM
Tandy's Avatar
Tandy
sounds about right will have a look when car next comes out if no one has come up with anything else
Old Feb 19, 2006 | 03:38 PM
cozzymatt's Avatar
cozzymatt
i had the same problem!!! on mine it was the mounting point under the n/s headlight which had broken!!! just replaced the plastic lug with a nut and bolt,, the bumper was removed at the time which made life a lot easier!!
Old Feb 19, 2006 | 07:41 PM
Escos Jam's Avatar
Escos Jam
tie wraps
Old Feb 19, 2006 | 10:07 PM
Rippers's Avatar
Rippers
Monte Geek
Found the problem as suggested above one of the mounts had broken off
Its Zip tied until I get a new one
Old Feb 20, 2006 | 02:24 PM
MONSTER's Avatar
MONSTER
you cant get em Paul, i tried
Ford will sell you a bottle but it doesn't come with the bracket (which you can't buy separately) for about Ł35
I did find a brand new bottle but the guy wanted Ł300
Old Feb 20, 2006 | 02:52 PM
Rippers's Avatar
Rippers
Monte Geek
Bracket? theres no bracket that I can see?
Old Feb 20, 2006 | 03:08 PM
MONSTER's Avatar
MONSTER
thats because yours is missing because its broke.....
there are 3 mounting points for an escoss washer bottle, 2 mount to the chassis rail the third mounts underneath the n/s headlight, this is the 1 that breaks, its an L shaped bracket which is plastic welded to a std mk5 escort washer bottle, this is the bracket which is no longer available...
HTH
Old Feb 20, 2006 | 03:24 PM
Franco's Avatar
Franco
Cable tie Paul, but a black one & not a white one like i did!
Old Feb 20, 2006 | 05:13 PM
THE RADMAN's Avatar
THE RADMAN
checked mine yesterday when i was under the car and its solid as a rock, suppose if you had a little knock/bump on that side it could easily snap the bracket off?
Old Feb 20, 2006 | 06:09 PM
Rippers's Avatar
Rippers
Monte Geek
Funny how many common problems cossies share!
Old Feb 20, 2006 | 07:21 PM
Rippers's Avatar
Rippers
Monte Geek
Do Escort Cosworth washer bottles have a warning switch?
Old Feb 20, 2006 | 07:32 PM
MONSTER's Avatar
MONSTER
They have a level sensor if thats what you mean?
Old Feb 20, 2006 | 08:30 PM
dave cos4x4
yes, the light comes on in the clocks for a warning the level is low.
Old Feb 20, 2006 | 09:19 PM
Rippers's Avatar
Rippers
Monte Geek
HTH
I get it now.. you made it sound like there was a seperate bracket part.
Microcat shows two types of washer bottles for the Escort Cosworth one with a warning switch and one without I'll double check whats availible
Old Feb 21, 2006 | 03:43 PM
Rippers's Avatar
Rippers
Monte Geek
Ordered a new one with level sensor Ł30+vat
Old Feb 21, 2006 | 03:49 PM
THE RADMAN's Avatar
THE RADMAN
good price for a cossy part,makes a change
Old Feb 21, 2006 | 04:23 PM
Franco's Avatar
Franco
Where from Paul?
Old Feb 21, 2006 | 04:40 PM
MONSTER's Avatar
MONSTER
If its the right one can you let me know please and i'll get one, when i ordered mine the bloke said 'its the right 1 for an escort blah blah' but when it came the bracket was missing, then after further digging he said it was no longer available!!
Old Feb 21, 2006 | 09:44 PM
Damo V's Avatar
Damo V
As Monster says I think you will find it will be wrong...
As above common fault snaping lugs off, mine was the same, though I just plastic welded it, solid as a rock now
Perhaps I should hunt one down and offer repaired items on EBay on an exchange basis
Old Feb 22, 2006 | 11:06 AM
Rippers's Avatar
Rippers
Monte Geek
I'll let you know when it arrives
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
155lee
Oct 24, 2015 11:11 AM
DavidK
Sep 27, 2015 02:55 PM
