Standard T3 Turbo's V's Hybrid T3's........
Old Dec 6, 2003 | 06:37 PM
CosRush's Avatar
CosRush
Default Standard T3 Turbo's V's Hybrid T3's........
What are the various options to make a Standard T3 better?
What about the various .48 housings etc...???
Any bits that could changed without requiring major reworking???
A T34....how is it different?
All wondered and never really got around to asking....
Old Dec 8, 2003 | 04:36 PM
CosRush's Avatar
CosRush
Surely somebody on here has experience with Turbos....
Old Dec 11, 2003 | 08:52 AM
Mike Gurney's Avatar
Mike Gurney
a stg 1 T3 has a 360 bearing
a Stg 2 has a larger 2wd compressor wheel
a stg 3 has stg 2 plus 48 ex housing
a 4x4 cossie has a larger compressor wheel
a T34 has a 63 ex housing and a larger compressor wheel and housing
and there are other options such as a 55 ex housing for example
what car is it for ?
Old Dec 13, 2003 | 12:12 PM
looking at his sig im guna take a guess and say its a dax rush with a cossie in it
Old Dec 13, 2003 | 03:07 PM
CosRush's Avatar
CosRush
Absolutely right
Im using a 4x4 Turbo which was reconned as a hybrid although i dont know what spec.
Thats why i was wondering if i could change the exhaust turbine housing or not?
and if so what to and what would be the benefit?
Old Dec 13, 2003 | 03:11 PM
all depends on if you need to mate, what sort of power are you wanting to get with the motor?
Old Dec 13, 2003 | 03:16 PM
CosRush's Avatar
CosRush
ive got a stage 3 330 converion to go on as soon as its run in
Old Dec 13, 2003 | 03:24 PM
mmm very simular setup to mine then i imagne. i am running a t34 with a .48 and 360 bearing and it does the job nicley, on the other hand my mate was running the same spec with a t33 (standard) turbo and that worked well too. (although he has just changed to a t34)
to be honest if your running 330bhp and your turbo has a 360 bearing i dont see any probs with sticking with it.
in that car you want as little lag as posible cause mine still goes sideways in 3rd when she boost's up!
Old Dec 13, 2003 | 03:31 PM
CosRush's Avatar
CosRush
Thanks for that.
Just out if interest have you tried any of the varoius methods for altering the boost characteristics, from the simple manual controller upto a boost programmer.
I was just looking at a website that uses a ball valve unit and a solenoid wire to a microswitch for full throttle.
This setup costing about £20 gave low boost (adjustable) then when full throtle or whereever you want it to full boost.
I like the sound of that, as for normal driving its not full on all the time until wot when you want it.
Old Dec 13, 2003 | 03:34 PM
sorry got to run to work at the mo but will tell you of my setup after 10.30. cheers
Old Dec 13, 2003 | 09:59 PM
at the moment my car was set up on high boost all the time (24psi)
but like you are probably thinkin this is just to much for normal driving and you go to overtake a car at normal pace and then it HELLLLLOOOOO!
when im rebuilding my car im going to just use a standard amal valve to give me high and low boost with an arming switch on the dash not on the throttle, that ones being saved for the nos arming switch!
Old Dec 14, 2003 | 12:39 AM
by the way just found this from a while back, you should definatly give it a read
http://passionford.webheberg.com/for...ic.php?t=16269
Matt Baxter
Sep 16, 2015 08:30 PM
IAN RS2k
Aug 18, 2015 07:51 PM
muz
Aug 16, 2015 12:57 PM
A.t.p
Aug 15, 2015 11:37 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
