S2 box onto S1
Old Feb 16, 2006 | 07:41 PM
David Ramsey's Avatar
David Ramsey
Default S2 box onto S1
Will this work? A mate of mine has offered me a s2 gearbox but I'm not sure if they're a straight swap.
Old Feb 16, 2006 | 07:48 PM
Oranoco's Avatar
Oranoco
Nope as the S2 box has no pick ups for the posh tie bar setup.
You can fit an S1 box to an S2 but not the other way round
Old Feb 16, 2006 | 07:52 PM
David Ramsey
Luckily there's nothing wrong with my box so I'll just keep mine for now, would have been nice to have a spare though.
Old Feb 16, 2006 | 09:10 PM
CliffRS4's Avatar
CliffRS4
You can fit an S2 box in an S1
Mine has an S2 box in mine. The gate as it's called is in the gearbox on the S2 where as it's below the gearstick on the S1.
The S2 box was put in mine and then the bits removed from underneath the gear lever.
Unless there was something done to mine that I don't know about
Old Feb 16, 2006 | 09:15 PM
©hatter Box's Avatar
©hatter Box
ciff what u going on about
as oranoco says he sums it up
Old Feb 16, 2006 | 09:40 PM
DazC's Avatar
DazC
So what have you bolted the front gearbox mounting to?
You can have an S2 box built up in an S1 gearbox casing with the H gate in the box OR in the gear linkage remote. (S1 has the H gate in the remote, S2 has the H gate in the box).
Old Feb 16, 2006 | 10:48 PM
CliffRS4's Avatar
CliffRS4
That's probably what's been done
Old Feb 18, 2006 | 05:22 PM
David Ramsey
Series 1's got LSD?
Old Feb 18, 2006 | 05:57 PM
MikeyXR2i's Avatar
MikeyXR2i
Originally Posted by David Ramsey
Series 1's got LSD?
Yeah they have its a viscous controlled LSD.
Old Feb 18, 2006 | 06:15 PM
David Ramsey
That's exactly what I always thought, some people been trying to tell me they haven't and that it only comes on an S2. Just thought I'd make sure, thanks mate
Old Feb 18, 2006 | 06:42 PM
DazC's Avatar
DazC
The S1 came with the LSD. The S2 also had one but they toned it down by drilling holes in the plates that work against the viscous fluid.
I ditched mine and fitted a Stage 2 Plus gearbox from CTS (Gearboxman) with Quaife ATB diff.
Old Feb 19, 2006 | 04:40 PM
David Ramsey
Are the gears longer on an S2 than an S1?
How much did you pay for your stage 2 gearbox DazC?
Old Feb 19, 2006 | 04:51 PM
Oranoco's Avatar
Oranoco
I think it's just 5th that's taller to aid motorway cruising..
Cliff mate I think you told me your box was an S1 box but with S2 ratio's
Old Feb 19, 2006 | 05:01 PM
David Ramsey
Might be worth using an S2 5th gear then if it's possible to put one into an S1 box if I get a new one made in future.
Old Feb 20, 2006 | 10:05 AM
JesseT's Avatar
JesseT
The final drives are completely different. S1 has 4.27 and S2 has 3.82.
AJC
Oct 8, 2015 11:09 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
