WHAT DO I NEED TO PUT 4WD REAR BRAKES ON 2WD..PLEASE HELP
JUST GOT SOME NEW 4WD DISCS AND NEED TO KNOW IF I NEED 4WD CALIPERS AND CALIPER MOUNTING BRAKETS TO FIT THEM.
WHAT OTHER MODELS USE THE SAME SET UP FOR THE CALIPER MOUNTS.
IF YOU HAVE DONE THIS PLEASE HELP SO I CAN GET ALL THE STUFF. THESE ARE THE REAR BRAKES AND CALIPERS IN QUESTION CHEERS MARK
the above is very true as that is exactly what i did , the only point i would mention is if you get second hand calipers from say Paul from North Yorks Spare (top bloke
) you will get the sliders as well but if you buy brand new 4by calipers you will still need to get some 4by sliders.
Originally Posted by MARKYMARKONE
hi
whats the difference with 2wd and 4x4 calipers as i was told there both the same and the only thing thats different on the rear brakes are the discs.
mark
mark
So the 4x4 calipers have to be wider to accept the wider discs
pauldowts
HI PAUL,
THANKS FOR YOUR REPLY RE 4WD REAR CALIPERS AND DISCS ONTO MY 2WD 3DR.
ARE THE 2WD SLIDERS THE SAME AS THE 4WD AS I AM BUYING THEM OFF A MATE BUT HE JUST HAS THE VENTED REAR DISCS AND CALIPERS [NO SLIDERS] AND WANT TO KNOW IF I NEED THE 4WD SLIDERS ASWEL CHEERS FOR ALL YOUR HELP.MARK
HI PAUL,
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
track.focus'd
Aug 12, 2015 05:53 PM
