oil pressure
Old Feb 15, 2006 | 12:14 AM
adrian2003's Avatar
adrian2003
Default oil pressure
hello what should a oil pressure gauge read for a good engine
Old Feb 15, 2006 | 07:02 AM
Rallyesport's Avatar
Rallyesport
About 1 bar at idle and 2.8 bar at 2000 RPM, normal temperature. These are minimun values. The pressure relief valve will open at 4 bar, so you won't see over 4 bar at normal operating temperature.
Old Mar 5, 2006 | 07:32 PM
paconassa's Avatar
paconassa
haynes manual says:
Minimum oil pressure at 80°C (176°F):
At 750 rpm . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.0 bar (14.5 lbf/in2)
At 2000 rpm . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.8 bar (40.6 lbf/in2)
Oil pressure warning lamp operates . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.3 to 0.5 bar (4.3 to 7.2 lbf/in2)
Old Mar 6, 2006 | 08:20 AM
Rallyesport
Actually the Ford workshop manual says 1 bar at 900 rpm, aprox. idle. And it's also at 10w-30, so if you are using a higher viscosity like 50, it's should be a little higher.
SMILER258
Sep 28, 2015 09:04 AM
