Willwood or Hi Spec?
Old Feb 14, 2006 | 10:44 AM
JamesS2RS's Avatar
JamesS2RS
Default Willwood or Hi Spec?
What would u use out of the two ?
Fast road / little track use.
Thanks,
Jim
Old Feb 14, 2006 | 11:38 AM
zippyobrien's Avatar
zippyobrien
wilwwod
Old Feb 14, 2006 | 12:02 PM
JamesS2RS's Avatar
JamesS2RS
Are willwood any good? I have herd mixed feelings about them
Jim
Old Feb 14, 2006 | 12:08 PM
zippyobrien
ive heard mixed reviews about hi spec. tbh, id go for ap. is it for the s2 or the focus rs?
Old Feb 14, 2006 | 12:25 PM
Lemon S2's Avatar
Lemon S2
I've got Wilwood on mine & have never had a problem with them, personally I would highly recommend them but as others have said some people have had problems with them.
Old Feb 14, 2006 | 12:46 PM
JamesS2RS's Avatar
JamesS2RS
It's for the S2 mate. I wish i cud put ap on it but @ 1600 quid for a set i dont think so.
I think i might give the wilwoods ago Im looking @ the SPL4 Kit with the 300mm disc.
Any other ideas pep's
Jim
Old Feb 14, 2006 | 01:08 PM
Micky's Avatar
Micky
Whats £1600 compared to good brakes that may stop you from killing yourself/youre passengers or innocent road users as you rip around the roads (or fast road use as you put it!!)?????? Time to kop on.Regards Micky
Old Feb 14, 2006 | 01:21 PM
JamesS2RS's Avatar
JamesS2RS
O Joy! So what you are saying there is I need 1600quid + worth of brakes to save my life!!! Im sure there are other brakes out there which will be ample for the job.
I can only spend 700-800 quid that is why I am looking at wilwood or hi spec.
Think I am going for the wilwoods and a wilwood brake bias set up.
Cheers,
Jim
Old Feb 14, 2006 | 02:06 PM
Andy-R's Avatar
Andy-R
Im pretty sure that Willwood are a subsiduary company of AP in the same way that Brembo are.
I've seen Willwoods used on numerous dedicated track cars.
Willwood would be my personal choice based on having seen them work and work well.
Old Feb 14, 2006 | 02:13 PM
JamesS2RS's Avatar
JamesS2RS
Cheers andy
Jimbo
Old Feb 14, 2006 | 03:38 PM
stevenebm's Avatar
stevenebm
post whore
gotta be hi spec.ave had wilwood and didnt like them
Old Feb 14, 2006 | 03:50 PM
JamesS2RS's Avatar
JamesS2RS
How cums mate? What didnt u like about them?
Cheers,
Jim
Old Feb 14, 2006 | 04:15 PM
stevenebm's Avatar
stevenebm
post whore
they just didnt stop the car very well compared to the hi specs.
Old Feb 14, 2006 | 04:19 PM
addiction's Avatar
addiction
what power is your s2 running?
Old Feb 14, 2006 | 04:33 PM
AJC's Avatar
AJC
comp brake do a set for 600 quid, better than ap and hi spec
paul and North yorks RS spares sells them
they are a 300mm 4 pot set
higly recommended
Old Feb 14, 2006 | 05:19 PM
swerv's Avatar
swerv
for the money i would get a set of brembo's [focus RS] and then get some custom bells and then get some 330mm rotors!!
this lot should come to around the same price as what your looking at.
hopr this helps
Old Feb 14, 2006 | 07:12 PM
JamesS2RS's Avatar
JamesS2RS
The car is gonna be running 300bhp or there abouts. Do u have a pic of the comps?
Yeah i might try the focus rs setup.
Jim
Old Feb 14, 2006 | 07:17 PM
JamesS2RS's Avatar
JamesS2RS
Im liking these: -
http://www.compbrake.co.uk/escort_rs_turbo.htm
Cheers,
Jim
Old Feb 14, 2006 | 09:04 PM
Chris69's Avatar
Chris69
do these large brake kits, 300mm or so fit behind th 15" rs turbo wheels?
Old Feb 15, 2006 | 08:29 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
300mm won't
Old Feb 15, 2006 | 09:52 AM
Kop2381's Avatar
Kop2381
Id go for willwood
Old Feb 15, 2006 | 12:51 PM
Combi_Chris's Avatar
Combi_Chris
i wouldnt go for either , id use some st brakes , and get the rear converted also
Old Feb 15, 2006 | 10:51 PM
NUTS RuS's Avatar
NUTS RuS
There is the pic of the compbrake one that fits under a standard wheel.
Its a lightweight alloy 4 pot caliper with bigger disc which is made as a disc and bell set up to avoid warp.
This set up has been tested in competition (by me) against Wilwood and blows it away without any questions.
Old Feb 15, 2006 | 11:12 PM
NUTS RuS's Avatar
NUTS RuS
Rear brakes should effectivly do sod all mate. The back of the car is so light that they are almost not needed.
Uprate the fronts first
Nov 1, 2015 06:53 PM
155lee
Oct 24, 2015 11:11 AM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
