phase sensor fitting
Old Feb 13, 2006 | 11:33 AM
Kam B's Avatar
Kam B
Default phase sensor fitting
just got a new phase sensor and was wondering if its a simple case of take of and refit, my mechanic told me that its not as simple as you need to set it or somthing :S
hows it done? thanks
Old Feb 13, 2006 | 11:45 AM
You need to set the gap between the sensor and the lug on the dizzy shaft.
Think its about .4mm but cant remember for certain off hand, should be in the manual though.
Old Feb 13, 2006 | 11:47 AM
Kam B's Avatar
Kam B
kool a mate told me 0.13thou gap
Old Feb 13, 2006 | 11:49 AM
Thats .33mm or so, so roughly the same as i remembered, so sounds about right to me mate.
TBH if you get it wrong, its quite obvious generally IME!
Old Feb 13, 2006 | 11:54 AM
rssapphowner's Avatar
rssapphowner
0.13 is good for big power cossies and normal mine is set at this and never have the spark blown out what so ever and got info from a good sorce
Old Feb 13, 2006 | 11:58 AM
The power thats being run isnt relevant to the optimum phase sensor gap (although RPM effects it slightly i should imagine) and the phase sensor gap has nothing at all to do with wether the spark gets blown out or not.
Are you sure you arent confusing it with plug gap? If so .013" sounds a little low to me personally.
Old Feb 13, 2006 | 12:28 PM
bud-weis's Avatar
bud-weis
Football Cwazy
manual says 0.2-0.3mm
CPS is 0.4-1.0mm
Old Feb 13, 2006 | 01:49 PM
rssapphowner
dissagre my friends sorry mines set at this and so is most of my other engines i have built with my partner in crime and dont have any probs
i aint gonna argue cos its sillly but if yours is setup that they its fine
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Anutternutter
Aug 21, 2015 06:07 PM
muz
Aug 16, 2015 12:57 PM
Zoggon
Aug 10, 2015 10:39 AM
