Where and what do u think?????
Old Feb 12, 2006 | 12:04 PM
tubbykev's Avatar
tubbykev
Default Where and what do u think?????
right all after some advice and your opinions if thats cool. Forst of all im after some advice on what kind of BHP u think i will make? I aint the foggiest to be honest and im sure plenty of you on here will have a good idea on what to expect.
Spec is as follows:
Accrilite low comp pistons
Burton Power Stage 2 head
Kent CVH 35 Cam Kit
Stage 3 T3 Hybrid Turbo
Radtec Front Mount
Collins Chips
Mongoose Full System
K&N Filter
Magnecor Leads
18 psi boost.
will have a vernier pulley if it is needed to dial cam in properly.
Next question is where is the best place to get it all setup and rolling roaded. I live in nottingham so is there anywhere u suggest?
Cheers for the advice all.
Old Feb 12, 2006 | 12:43 PM
Oranoco's Avatar
Oranoco
You should be fine with more boot than 18psi if it's set up right. Would guess about the 220-230bhp mark
Old Feb 12, 2006 | 12:53 PM
rs_daz's Avatar
rs_daz
Old Feb 13, 2006 | 05:19 PM
ivorbiggun's Avatar
ivorbiggun
Jamie @ Jamsport every time
