4 x 4 Crank - what size should it be?
Old Feb 11, 2006 | 04:35 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Default 4 x 4 Crank - what size should it be?
Hi folks,
Anyone know what size a standard Cos 4 x 4 Crank bearings should be?
I'm about to buy one that is :
"main ends are 57.02mm and the rod ends are 52.01mm"
Is this standard size? Or has it been machined?
Anyone know?
Simon
Old Feb 11, 2006 | 06:45 PM
Si B's Avatar
Si B
Answering my own question as noone else has
According to Technicians manual:
Main Bearing Journal Diameter 56.975 - 56.959
Crank I'm buying: 57.02mm
Big End Journal Diameter 51.993 - 51.977
Crank I'm buying: 52.01mm
So by my reckoning that's bigger than standard! Oversized crank? Is that a mod or something? Cool
Realistically though i guess it's poss slightly inaccurate measuring, but at least it sounds too big rather than too small!
Si
Old Feb 11, 2006 | 08:03 PM
costina's Avatar
costina
Live long and prosper!!
Your right m8 the only way to measure is with a micrometer something like a digital vernier is not that accurate
Looks like you got ur self a unground one
Old Feb 11, 2006 | 08:07 PM
Si B's Avatar
Si B
cheers costina - it was measured with a digital vernier apparently.
Will measure it myself when it's here just to double check - I'm building a 500 bhp engine so it needs to be right!
Si
Old Feb 11, 2006 | 08:22 PM
peteh's Avatar
peteh
Old Feb 11, 2006 | 08:43 PM
Si B's Avatar
Si B
Peteh
Many thanks in advance matey!
Old Feb 11, 2006 | 08:45 PM
larks's Avatar
larks
you made your mind up on your engine spec yet then m8?
Old Feb 11, 2006 | 08:49 PM
Si B's Avatar
Si B
Evening Steve,
Nearly sorted the spec, but all I know for certain is the bottom end needs to be strong hence this crank!
Still no turbo or injectors though! Still undecided / haven't got the definitive answer on that part. 500 bhp is sooo tempting, but is the outlay worth it?
Got any pics of the new beastie you can send me?
Simon
Old Feb 11, 2006 | 08:56 PM
larks's Avatar
larks
no pics yet will take you for a blast tomorrow night.shes not to bad needs a couple of parking dings sorting,some paint then konis,wheels,brakes and of course more power
Old Feb 11, 2006 | 08:58 PM
Si B's Avatar
Si B
Interestingly, I have some Konis, and some Greens, or Greys, and two chips, and a turbo that would all fit nicely on your car!
Tomorrow night will be cool - could maybe do with a lift up as not sure if Phil is going at the mo...
Simon
Old Feb 11, 2006 | 09:02 PM
larks's Avatar
larks
no probs give me a bell tomorrow m8..
are 4x4 konis and 2wd konis the same?????
Old Feb 11, 2006 | 09:05 PM
Si B's Avatar
Si B
I don't think they are to be honest, tho I'm sure they could be persuaded to fit with a small sledge hammer!
Maybe someone else reading this will no for sure...
At least parts for 2wd cars are very common - always big brake kits etc cropping up in the parts for sale. Keep your eyes peeled
Old Feb 11, 2006 | 09:08 PM
larks's Avatar
larks
sledge hammer lol
prob need one to knock out the dents when i hit a tree trying to drift it
boeb
Jan 9, 2020 05:11 AM
Johnny Knoxville
Sep 30, 2015 07:21 AM
pabloXR
Sep 21, 2015 12:42 PM
alexbarnes95
11
Sep 15, 2015 10:26 AM
