Fiesta RS Turbo Wales
Old Feb 11, 2006 | 04:24 PM
danfrst's Avatar
danfrst
Default Fiesta RS Turbo Wales
Can anyone recommend a reliable garage in South Wales area i can take my FRST?? Somewhere where they know what theyre talking about!
Old Feb 11, 2006 | 04:45 PM
white cab's Avatar
white cab
what do you want done to the car m8 cos there aint many good garages round here my friend bristol to interpro being the main good 1
Old Feb 12, 2006 | 09:14 AM
danfrst's Avatar
danfrst
Hello m8- i want it generally checked over really, having a few problems now, radiator hose blew recently, then brand new replacement blew within a week!?! Guess that means deeper problems? Interpro Bristol is close enough!- you'd recommend them yeah? Do you know anything about Severn Valley Motorsport (theyre just over the bridge i think!?), would they work on a fairly standard Fiesta RST? What are they like?
Old Feb 12, 2006 | 04:31 PM
white cab's Avatar
white cab
are you sure the radiator hose isnt rubbing on anything before you put it into a garage.Also back flush the rad to ensure there are no blockages and is there water in oil or oil in water, just simple checks like this you can get a better idea on what is wrong as if the head gasket has gone it can lead to high water temps which creates high water pressure which could lead to a burst hose. i would myself only take it to a specalist to get the engine set up or if there is a major problem with the car. even putting a new head gasket on the car isnt much of a job really if you know what you are doing.
Old Feb 12, 2006 | 04:39 PM
M Brian's Avatar
M Brian
not heard much about severn valley recently but of the cars ive seen prepared by them they did look to be to quite a high standard.
worth giving them a ring aswell just to check what they think.
Old Feb 12, 2006 | 06:24 PM
rauri's Avatar
rauri
up in smoke........
i had the same problem with my bottom radiator hose when i first got my frst....it was caused by a fooked gearbox mount...the engine was moving and the altenator was rubbing on the hose causing it to burst
Old Feb 12, 2006 | 06:35 PM
Brookesy's Avatar
Brookesy
I think theres a garage near you Dan called Westec
paceo
Feb 3, 2016 10:31 AM
carlo
24
Oct 5, 2015 08:20 PM
s1turboman
Aug 29, 2015 04:27 PM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
