standard set up rst - 12psi???
Old Feb 11, 2006 | 12:24 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Default standard set up rst - 12psi???
My car suddenly started boosting to 12psi, it was set up completely standard recently on a RR and hasnt been drove much since. it has a chip, -31 was seeing 7psi when it left the RR and has no bleed valve and i have not touched the amal valve, or actuator and it is also piped up standard.
Any suggestions WHY this may be happening?
one thing I can only think of is when i fitted the turbo it had a little piece of mud in the actuator bit where the hose connects, i picke dmost ouf it out and thought nothing more of it as the car ran perfectly, could a little pice of mud block the pipe and make it run 12psi?
Old Feb 11, 2006 | 12:32 PM
Robin's Avatar
Robin
actuator starting to go soft??? could be your wastegate is starting to stick, mine was doing this and was one of the resions it was boosting so much
Old Feb 11, 2006 | 01:24 PM
vroooom ptssssh
It Wasnt Me!
Suerly if the actuator went soft, it would either peak high and tail off considerably (it tails off maybe 1-2psi if that) OR wouldnt peak high at all.
Considered the wastegate sticking actually! as it isnt used often, would i need to disconnect the actuator and feel for how free it is and loosen it off?
thanks
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
A.t.p
Aug 15, 2015 11:37 AM
dlwarrior
Aug 5, 2015 10:19 AM
