Sunroofs and rust
Old Feb 11, 2006 | 10:05 AM
FusionRS's Avatar
FusionRS
Default Sunroofs and rust
Im in the middle of having a load of welding and new panels on my S2, but ive now had a look under the headlining and its not pretty.
Theres quite a bit of rot on the sunroof channels and the guy welding it up isnt too optimistic about it.
He said he can either:
1. Have a go and do the best he can at sorting it out
2. Get rid of the channels and just put a 'vertical pop' sunroof in (i cant think of any other way to describe em!)
3. New roof skin - get rid of the sunroof altogether
Has anyone had a problem like this and any suggestions??
Thanks in advance for any advice.
Nick
Old Feb 11, 2006 | 10:20 AM
Micky's Avatar
Micky
This is a very very common problem on RST's.In fact I scrapped my shell because of this very reason.A new roof skin to get rid of the sunroof altogether would be the best idea in my opinion,but new roofskins (with or without a sunfoof opening) are not available brand new from FORD or anywhere else it would seem.Best bet is to cut one off a car down the breakers yard.Its not easy to do,as the roof is a major structural item,youre body builder will have to be very very good!!!A few people on here have got all the rust cut out of their roof,welded in new metal and then spray a f*ck load of waxoil under the roofskin,it worked for some,but the rust came back with others.Hope this is of info to you.Do a search on here as it has been talked about before over the years.All the best Micky
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
