computer people plz look
looking at getting more memory for my comp at mo only 256mb,so gonna go down pc world and go bye some more now do i need DDR MEMORY OR SDRAM MEMORY
PLEASE HELP THANKS
PLEASE HELP THANKS
Its DDR mate, also you need to check its the right MHZ, for example the exact sticks my pc takes is pc2700 DDR 333MHZ. You need to know all 3 bits of info, get one wrong and it wont work!
how do i find that out
You take the stick you already have, out of the PC and look at it - it will tell you on the stick the specifics of what it is. Better still, take the stick with you and ask for an identical stick
Try using the Belarc Advisor - www.belarc.com
It will tell you what type of memory you have, then you'll be armed when buying the upgrade.
Try aria.co.uk, they are pretty cheap, or even novatech.co.uk.
Matt
Matt
mk3ste
Oct 17, 2021 10:09 AM
rsguy
44
Sep 29, 2015 03:29 PM
