part numbers for clips underneath
I need to pop into ford 2moro and order all the clips underneath the car that hold the fule lines and brake lines to the chassis rails and the actual tank itself. Seeing as my local fords seems to have its fair share of numpties, can anyone help me with some part numbers for these?
It would be much appreciated
thanks in advnce
Danny
thanks in advnce
Danny
Hello mate
Someone else asked this one a few weeks back, must be a common thing with Ford Staff
My local dealer is ok, the part number i have on my bag is:
6110209
And just incase they can't order you what you want from the part number (
), there is 2 variations, you want the 8mm + 8mm + 5mm + 5mm.
The one you DON'T want is the 8mm + 6mm + 5mm + 5mm, this is for the carbeuretor models and has a smaller return line
6110209
), there is 2 variations, you want the 8mm + 8mm + 5mm + 5mm.The one you DON'T want is the 8mm + 6mm + 5mm + 5mm, this is for the carbeuretor models and has a smaller return line
155lee
Sep 6, 2016 11:10 AM
