Wastegate chatter
Old Feb 10, 2006 | 09:10 PM
TGTURBO's Avatar
TGTURBO
Default Wastegate chatter
On a small turbo escort cos is it possible to get wastegate chatter the same as a big turbo model please hel p cheers
Old Feb 10, 2006 | 09:29 PM
S1rst's Avatar
S1rst
Yep ive got it. Pretty loud too!!! I think its just a case of, the more boost you run, the louder it is.
Old Feb 11, 2006 | 08:06 AM
ESCYSCOTT's Avatar
ESCYSCOTT
depends on the turbo too.........My girlfriends saff used to chatter like fook on about 23psi with a T34 and a cone filter but my Escos runs 2.1bar (31psi) on a GT28 roller bearing turbo and with the cone filter fitted, it only just say "flutters" ............thats why I took off the filter and put the airbox back on as it is quicker and more responsive with the box on.
It isnt actually the wastgate chattering, its the boost pressure that hits the compressor wheel on vacuum when you back off........so I've been told. thats why you hear it through your filter
Old Feb 12, 2006 | 06:03 PM
Damo V's Avatar
Damo V
As above, its not wastegate chatter, but the turbo blades chopping the backpressure
Old Feb 12, 2006 | 07:42 PM
mxquattro's Avatar
mxquattro
say what? Its blow off valve.
Old Feb 12, 2006 | 07:44 PM
Damo V's Avatar
Damo V
Sorry?
Old Feb 12, 2006 | 09:06 PM
Redkop's Avatar
Redkop
He's asking about a SMALL turbo... T25/T28 not a T34. So you are unable to run high boost on a small turbo... 18psi max. When mine was small turbo, it had a slight 'chatter' hardly anything at all really.
pabloXR
Sep 21, 2015 12:42 PM
coscor86
Sep 20, 2015 01:21 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
Aug 14, 2015 07:29 AM
rsstav
Ford Focus ST Parts for Sale
Aug 11, 2015 04:19 AM
