++++Problem with Focus Rs Help ++++++++++++++++++++++++++
Old Feb 10, 2006 | 08:16 AM
JamesS2RS's Avatar
JamesS2RS
Default ++++Problem with Focus Rs Help ++++++++++++++++++++++++++
I have a problem with my Focus Rs any constructive comments would be appreciated.
Problem: -
Under hard acceleration in 1st 2nd and 3rd I get a really funny noise coming from the turbo, It’s like a squeaky belt noise but mechanical noise if you no what I mean. I was running a baileys dump valve and the problem was only intermittent. Last night I fitted the Standard re-cycling dump valve and the noise is there every time I put my foot down.
Any ideas??????
Jim
Old Feb 10, 2006 | 03:42 PM
THEDMAN's Avatar
THEDMAN
Any chance it is an air leak under boost?
Are all your hose tight?
Has one of the hoses split? And it is opening under boost?
Had this before, sounds like a metallic squeal!
Old Feb 10, 2006 | 03:51 PM
JamesS2RS's Avatar
JamesS2RS
Thats the sound mate it nasty! cud it be a gasket ?
Jim
Old Feb 10, 2006 | 04:23 PM
THEDMAN's Avatar
THEDMAN
Make sure that all the jubille clips are tight on the hoses as if one of these is loose it sounds like a high pitched squeal.
A split in one of the boost hoses is another option as the split will not open up until under boost and also make the squealing noise.
Absoloute worst case scenario is the turbo roller bearing......
Hope this helps!
Old Feb 14, 2006 | 06:42 AM
Willow's Avatar
Willow
Helps me too!!!!
Just fitted bluefin at the weekend and I got the same problem - never had it before.
Thanks for the advice
Old Feb 18, 2006 | 07:21 PM
JamesS2RS's Avatar
JamesS2RS
Originally Posted by Willow
Helps me too!!!!
Ive checked everything and it stills ramdomly does it Ford have look all over the tested it for two day and can not find anything wrong with it
Old Feb 23, 2006 | 07:27 PM
JamesS2RS's Avatar
JamesS2RS
Fitted a de-cat today and the nosie is guaranteed to come in every time i put my foot down
When i slightly touch the gas i get a little rattal which sounds like it coming from inside the turbo any ideas??
Jim
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
