cossie vibration
Old Feb 9, 2006 | 06:13 PM
spinusdisplacius's Avatar
spinusdisplacius
Default cossie vibration
hi i,ve got a 92 4x4 cos, when you drive it you get a faint vibration, a sort of dull buzz through the whole car it doesn,t seem to get worse or better with speed dont know where to start looking cheers
Old Feb 9, 2006 | 09:12 PM
martinmace's Avatar
martinmace
check the prop shaft, drive shafts would be a start, also get the wheels balanced.
Old Feb 10, 2006 | 07:17 AM
spinusdisplacius
what happens when your transfer/gearbox is on the way out? how do you check propshafts and driveshafts ?
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
