smokin fuse box
Old Feb 8, 2006 | 07:02 PM
rst230bhp's Avatar
rst230bhp
Default smokin fuse box
Hi all
got a problem with my s2 the other day was stuck in traffic and i get a load of smoke out of the bonnet, opened it and the smoke was coming out from the fuse box. i have had the fan on direct, so i suspect this was the cause. i have replaced blown fuses and took the fan of direct, car runs but front heated screen and heaters dont work, and the alarms started playing up. i have checked and replaced all fuses. is there anything else i can check, do i need to replace the fuse box. pls help
Old Feb 8, 2006 | 07:35 PM
sufsRS's Avatar
sufsRS
relays? if you keep the fan on permanately it will burn out the yellow relay in the middle, replace it if it looks damaged
Old Feb 9, 2006 | 08:22 AM
turbo.jon's Avatar
turbo.jon
My fuse box caught light this was due to the headlight relays heating up and melting had to change whole loom in the end as fuse box was fooked
Old Feb 9, 2006 | 11:41 AM
Rick's Avatar
Rick
Where's the explosion pic?!
Old Feb 9, 2006 | 11:59 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Never fear.... Tony is here!
Old Feb 9, 2006 | 12:09 PM
Old Feb 9, 2006 | 07:11 PM
rst230bhp's Avatar
rst230bhp
Cheers guys
will check all relays
at the explosion pic
AJC
Oct 8, 2015 11:09 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
