hub nut size
Old Feb 8, 2006 | 06:52 PM
phil robson's Avatar
phil robson
Default hub nut size
does anyone know the size of the rear hub nuts on a 2wd saff?
i know its 41 or 42mm but not sure which one
cheers
Old Feb 8, 2006 | 06:55 PM
dazzle740's Avatar
dazzle740
hi there mate
pretty sure it's 42mm i had to buy one not so long ago to do my rear wheel bearings.
Old Feb 8, 2006 | 07:50 PM
allsteel's Avatar
allsteel
If it's the same as Escos it's 41mm cos i've just had to pay £11 for one.
Old Feb 8, 2006 | 09:06 PM
pee vee's Avatar
pee vee
yeah 41mm, had to take mine off the other day!!
(4x4) its almost certainly the same
Old Feb 9, 2006 | 06:11 AM
grunter's Avatar
grunter
41mm it is just got one
Old Feb 9, 2006 | 07:45 AM
foreigneRS's Avatar
foreigneRS
Testing the future
also concur with 41mm - opened mine up on monday to put some shims in between hub and trailing arm to correct camber
Old Feb 10, 2006 | 08:26 PM
dazzle740's Avatar
dazzle740
ooopps just checked in my toolbox that be 41mm socket.
Old Feb 11, 2006 | 03:09 PM
phil robson
thanks chaps
boeb
Jan 9, 2020 05:11 AM
fordrallycar
Sep 30, 2015 07:57 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
DavidK
Sep 27, 2015 02:55 PM
