Help Needed....... Escort Gti
Had the car for a while, its done 75k but when it reaches about 3000rpm, there appears to be a slight hesitation, it has been like this for a while and until now has just been a little annoying.
Took the car out today and when it reached about 2500rpm the car seemed to lose all power, this was only for a split second and then all appeared to be fine again
any ideas what this could be?
Any help would be much appreciated
either ecu, or plugs / leads, reset the ecu... remove battery for as long as you can, then start it up and give it chance to idle for a bit then take it for a run getting through all the gears. if the problems still there could be missing or getting a weak spark so from there check all leads are in good order and on properly and that all plugs are gapped correctly and not cracked or over fouled with deposits
after that it maybe a fuelling issues, but it may well be the ecu
worth cleaning your maf while its resetting
hello sorry to hijack the post, was wondering if anybody can help, i have bought an escort gti that has a problem ideling?? i have been told it maybe the icv (idle control valve) is this correct or could it be something else???
Dr. Ickxs
Sep 15, 2015 10:15 PM
