FAO Lee @ fusion
Old Jul 22, 2004 | 01:53 PM
DaveEscos's Avatar
DaveEscos
Default FAO Lee @ fusion
Lee,
If i sent you a Bailey power steering tank, could you lop off the outlets and weld some threaded unions in place.. AND also weld a bracket on to the side of it so I can mount something to it?
cheers ears
Dave
Old Jul 22, 2004 | 02:14 PM
GARETH T's Avatar
GARETH T
mmmmmm wonder what the the unions are for
Old Jul 22, 2004 | 02:18 PM
Tony Ryan's Avatar
Tony Ryan
Im sure Lee could manage all of that ! Can i ask if your going to aeroquip the power steering pipes to the rack as that is something ive thought about but haven't looked into yet ?
Pm me if you prefer .
Tony
Old Jul 22, 2004 | 02:19 PM
Ryan's Avatar
Ryan
tony im almost 101% sure dave's going to do that
he eats, sleeps and shits aeroquip
Old Jul 22, 2004 | 02:21 PM
Tony Ryan's Avatar
Tony Ryan
aaahhh ! then my question is - where do you weld the fittings, onto the pipe or directly onto the rack where the column end is ?
Rene's Avatar
Rene
Old Jul 22, 2004 | 02:23 PM
Ryan's Avatar
Ryan
me personally i would get get the rack tapped and have the unions going directly into that, but its alot of work.
not sure what the bling boy is doing in regards to your question
lets see what the pink shirt wearing poof has to say
DanS's Avatar
DanS
lee if you do read this....
Cheque was posted today, should be with you tommorow
Old Jul 22, 2004 | 02:24 PM
DaveEscos's Avatar
DaveEscos
cor, ive just laid a -16 45 degree union!
christ!
yes im quiping the power steering system. reason being
a) i fucking LOOOOVE aeroquip
b) the std system seeps a hell of a lot, hydraulic fittings will sort this out a treat
Old Jul 22, 2004 | 02:50 PM
Tony Ryan's Avatar
Tony Ryan
I would be very interested to hear how you get on with this , mines a 2wd
rack but the job will be much the same , are you going to weld on male JIC fittings on the rack itself or join on the metal hoses ?
Old Jul 22, 2004 | 03:08 PM
DaveEscos's Avatar
DaveEscos
Tony, the easiest would be to use heat shrink over the ends, then jubiliee clip to the rack.. but.... as you say, doing it properly involves JIC unions at each inlet / outlet.
i shall keep you updated
Old Jul 22, 2004 | 10:20 PM
DaveEscos's Avatar
DaveEscos
back up
Old Jul 22, 2004 | 11:11 PM
Danny B's Avatar
Danny B
any fab place could do this for you if LEE doesn't read this.
Old Jul 23, 2004 | 10:10 AM
RichardPON's Avatar
RichardPON
I thought about quipping my PAS system, as I've got the PAS cooler in the return line......................
Old Jul 23, 2004 | 10:31 AM
Project ST's Avatar
Project ST
Sure he can do that for you chap Not sure if he can weld in burberry tho...
/Munk
155lee
Oct 27, 2015 04:55 AM
deathrider666
Sep 28, 2015 06:12 PM
little bram
Sep 7, 2015 11:59 AM
155lee
14
Aug 22, 2015 12:15 PM
