can anyone help
Old Feb 7, 2006 | 08:38 PM
esccossie666's Avatar
esccossie666
Default can anyone help
s1 rs turbo boosts up fine in first and second but when into 3rd and higher it cuts out
the rev counter drops off,if you hold your foot down when the revs drop it picks back up again or if you take your foot off the throttle and back on it goes again
dose anyone have any ideas
Old Feb 20, 2006 | 08:26 PM
esccossie666
up
Old Feb 21, 2006 | 04:55 PM
davecosworth's Avatar
davecosworth
IM BACK
what boost pressure you running at mate and is it chipped
Old Feb 21, 2006 | 08:50 PM
esccossie666
standard ecu m8 running 14 psi
have tryed changing ecu and dissy still the same
Old Feb 21, 2006 | 10:00 PM
bud-weis's Avatar
bud-weis
Football Cwazy
A standard ECU will only allow around 10psi at most before cutting the ignition, which i think is what your experiencing. either get the boost turned down or have a chip fitted, standard boost is about 7-8psi
Old Feb 21, 2006 | 10:19 PM
davecosworth
IM BACK
as above mate. turn the boost down or get it chipped
Old Feb 21, 2006 | 10:21 PM
Ben26's Avatar
Ben26
im running my boost on 10 psi which is the max u can run on a standard ecu
Ben
Old Feb 21, 2006 | 10:28 PM
esccossie666
cool will get that sorted 2 morrow and let you know if that sorts it
thanks for your help
