2wd oil pump fittings
Old Feb 7, 2006 | 07:18 PM
bigjim172000's Avatar
bigjim172000
Me Cossie Runs Atlast!!!!
Default 2wd oil pump fittings
on the 2wd saphy oil pump where the pickup tube bolts down is there a spacer under it cos i have about a 1inch gap between it and the block, any pictures of the bit i need or the setup would be greatfull
James
Old Feb 7, 2006 | 07:45 PM
ricky_3dr's Avatar
ricky_3dr
There isn't a spacer, the bracket bolts directly on to the block, make sure that the oil pickup pipe filter is the correct distance from the sump, if it isn't you'll have an issue with oil starvation
Old Feb 7, 2006 | 08:44 PM
bigjim172000
is there a gasket under the oil pump where it bolts to the block aswell?
Old Feb 8, 2006 | 12:03 AM
jon@work's Avatar
jon@work
No
Old Feb 8, 2006 | 02:15 PM
bigjim172000
just had a look at it today and there is no way the oil pick up tube is going to meet the block. i will take some picks and show you all
RUBY123
Oct 22, 2023 12:04 PM
big_Rad
Sep 15, 2017 09:36 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Dubs44
Aug 21, 2015 02:42 PM
track.focus'd
Aug 12, 2015 05:53 PM
