ST24 POWER PROBLEM
Old Feb 7, 2006 | 06:19 PM
Ally D's Avatar
Ally D
Default ST24 POWER PROBLEM
Purchased a 98 reg st24 in november, 105000 miles on clock. Got full service history with it. Last job done on it was last August when it had an overheating problem, engine was stripped and had valves checked,found to be okay. IT has allways seemed to lack power so i had it put on rolling road to test hp and was found to be 40hp down{mid range crap} initial check looked like cat was nakad so had it replaced+ emmisions check which ruled out oxy sensors. Still no better put it on computer to see if any faults, came back with i.m.r.c. fault was told that the solaniod control might need replaced or flaps could be sticking. Is this the cause of the power problem or could there be other reasons ? ie mass sensor Please HELP !!!
Old Feb 7, 2006 | 10:19 PM
CossieEdd's Avatar
CossieEdd
Have a look over on www.fordmondeo.org as this does sound like the IMRC has given up the ghost (quite common & due to heat soak).
HTH
Edd
Old Feb 7, 2006 | 10:28 PM
Ally D's Avatar
Ally D
cheers will have a look at that other site
CrOwSoN15
Sep 10, 2015 07:33 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
hopper350
Sep 4, 2015 12:53 AM
