Anyone used JB Weld?
Old Feb 6, 2006 | 03:12 PM
James's Avatar
James
Default Anyone used JB Weld?
it says on the packet leave to dry 4-6 hours if +10oc, drying time can be shortened if a little heat is used.
well i've stood said item infront of my fire, how long should i leave it?
the temp there is 45oc, would a hour do?
Old Feb 6, 2006 | 03:27 PM
James's Avatar
James
all the people online atm and not one of you a bodger!?
Old Feb 6, 2006 | 03:30 PM
FordFans's Avatar
FordFans
Yeah I've used it and it's shite, use chemical metal instead if you must.
Old Feb 6, 2006 | 04:39 PM
Rick's Avatar
Rick
"can be tapped, machined, cut.." id like to see u try!
boeb
Jan 9, 2020 05:11 AM
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
