faulty coolant sensor
Old Feb 6, 2006 | 10:06 AM
rs cos's Avatar
rs cos
Default faulty coolant sensor
the one at the back right of engine, if this was faulty what would happen?
Old Feb 6, 2006 | 10:09 AM
RichardPON's Avatar
RichardPON
In my case, it was massive overfuelling, very difficult to start, ran like a pig.
Old Feb 6, 2006 | 10:13 AM
rs cos's Avatar
rs cos
dont think thats my problem then, it starts fine its only when it gets warm it starts to play up
Old Feb 6, 2006 | 10:22 AM
Rossco's Avatar
Rossco
On my dads Cossie it started and ran fine when it was cold, took it up the road, came on boost a couple of times then just cut out, was a right pain to start and over fueled. Managed to start it eventually got a couple of mins down the road taking it proper easy, then cut out again.
Old Feb 6, 2006 | 10:33 AM
Stu @ M Developments's Avatar
PassionFords Creator
CTS is a thermister that changes resistance according to temperature and it can fail ANYWHERE in the temp range.
IE: Can be fine cold yet fail hot, fine hot but fail cold, fine hot and cold but fail warm..... possibilities are endless.
Old Feb 6, 2006 | 10:35 AM
Rossco's Avatar
Rossco
On my dads it had not failed it was the wires on the plug had been damaged and fixed with a peice of matchstick!
Old Feb 6, 2006 | 11:35 AM
trotty's Avatar
trotty
so could such item cause the revs to dip if it was faulty??
rapidcossie's Avatar
rapidcossie
me too
Old Feb 6, 2006 | 11:37 AM
foreigneRS's Avatar
foreigneRS
Testing the future
if it's completely failed, or the connection is broken, it will throw up a fault code that can be read from the diagnostic port (as will all of the other sensors)
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
