HOW OFTEN DO YOU CHECK
Old Jul 21, 2004 | 11:47 PM
Alvyn's Avatar
Alvyn
Default HOW OFTEN DO YOU CHECK
nuts and bolts that hold your cars together,suspension,driveshafts mounts etc?
Old Jul 21, 2004 | 11:54 PM
NMS Badboy^NUTTER^'s Avatar
NMS Badboy^NUTTER^
Alvyn,
i check mine every couple of thousand miles, go around the underneath with a torque wrench, and do a spanner check in the engine bay
Cheers Jonno
Old Jul 22, 2004 | 03:52 AM
NUTS RuS's Avatar
NUTS RuS
Too many times
Old Jul 22, 2004 | 06:01 AM
SS1's Avatar
SS1
lots since i lost my n/s/f wheel on a r/s turbo s2 at 80 mph on the a59 on my way to work ..its scary when you hear a bang look left and see your wheel bounce out the arch and fook of left.. ..only minor damage though disk brake..arch side skirt...black rubber on wing mirror ...and a square wheel in a farmers field in burscough...all wheel nuts where loose..only locking nuts holding them on...this happend at half 4 in the morning...peak hour... ..somebody could have died...just think if you see somebody trying to rob a set of wheels..
Old Jul 22, 2004 | 07:36 AM
Alvyn's Avatar
Alvyn
I must admit I DON'T really check it that often(only when I hear something loose) BUT guess I should start NOW as components are certainly under alot more stress now
Old Jul 22, 2004 | 08:06 AM
NUTS RuS's Avatar
NUTS RuS
Dont be tempted to overtighten things tho mate.
Always use a torque wrench
Old Jul 22, 2004 | 10:06 AM
John Laverick's Avatar
John Laverick
Sounds like someone tried to steel your wheels mate!!
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
