METERING UNIT HELP
Old Feb 4, 2006 | 06:58 PM
robbob's Avatar
robbob
Default METERING UNIT HELP
DONT SUPPOSE ENY ONE HAS A CLEAR PICTURE OF A METERING UNIT OF A SERIES 2 INCLUDING ALL THE WIRES AND INJECTORS
Old Feb 4, 2006 | 11:03 PM
XR2's Avatar
XR2
Do you need a picture what is inside or just where the injection lines are connected?
Old Feb 5, 2006 | 07:10 AM
robbob's Avatar
robbob
JUST SO I CAN SEE WERE THR INJECTORS ARE CONECTED TO
Old Feb 5, 2006 | 07:35 AM
HORNETS7's Avatar
HORNETS7
i will take a pic for u !
watch this space in the next hour lol
Old Feb 5, 2006 | 07:49 AM
XR2's Avatar
XR2
Just to the four outer holes. You can see it by the lenght of the injection lines which one belongs to the right hole. But it makes no difference if you mix them up
Old Feb 5, 2006 | 07:56 AM
HORNETS7's Avatar
HORNETS7
well heres the pic i got for u and ive numbered up the lines in case!
http://img.photobucket.com/albums/v2...gheadpipes.jpg
Old Feb 5, 2006 | 02:22 PM
robbob's Avatar
robbob
GOT ALL THE FOUR RIGHT BUT THERS ALSO A INJECTOR PIPIE JUST A SMALL ONE ONE SIDE IS CONNECTED AND IT SAYS IN AND OUT ON IT ITS SLIGHTLY HIGHER THAN WERE THE FOUR INJECTORS GO
Old Feb 5, 2006 | 03:13 PM
Puss2's Avatar
Puss2
Formerly know as Puss
dont know if it will help
Old Feb 6, 2006 | 06:24 PM
SafeChav's Avatar
SafeChav
Hello again mate
The liitle thing you are talking about is the fuel flow sensor for the fuel computer (you do have a fuel computer right??). IT makes no odds at all which injector line this goes in, it only tells the computer the flow rate in the injector line (all 4 lines having the same flow rate), but if you have all the proper pipes it should IIRC go inline with the injector for number 1, the IN side going to the metering head, and the OUT side to the injector.
Have you identifed whether your metering head or injector is at fault?
Old Feb 6, 2006 | 07:09 PM
robbob's Avatar
robbob
YEAH MATE I HAVE A FUEL COMPUTER RIGHT SO ILL PUT THE PIPE ON ON NUMBER ONE INJECTOR WITH NUMBER ONE ON TOP OF THAT BUT WHAT GOES ON THE OTHER SIDE OF THIS SORRY TO SOUND STUPID LOL
Old Feb 6, 2006 | 08:04 PM
SafeChav's Avatar
SafeChav
sorry im a little confused now? Have u just converted to KE Jetronic then or something? There should be a very short pipe from the metering head to the sensor, then the injector line for that sensor is different to all the rest (doesnt need to go to the metering head obviously)
Old Feb 6, 2006 | 08:17 PM
robbob's Avatar
robbob
YEAH IVE GOT THE LITTLE PIPE SORTED IVE PUT IT UNDER NUMBER ONE INJECTOR WAS JUST WONDERING WHAT GOES IN THE OTHER SIDE OF THE FUEL COMPUTER THINGHY
Old Feb 6, 2006 | 08:22 PM
SafeChav's Avatar
SafeChav
the injector pipe then, to run the fuel computer there is a different pipe for that injector as it has to connect to the flow sensor rather than directly to the metering head, so 3 injectors go straight to the metering head, and the other via the flow sensor. Does that makes sense?
Old Feb 6, 2006 | 08:44 PM
robbob's Avatar
robbob
YEAH SO 3 INJECTORS ON THE METERING UNIT AND THE FOURTH PUT THE FUEL COMPUTER PIPE ON THE SPARE AND THE SPARE INJECTOR PIPE GOES ON THE OTHER SIDE OF THE FUEL COMPUTER ITL HAVE TO BEND ABIT IS THIS OK
Old Feb 6, 2006 | 10:04 PM
SafeChav's Avatar
SafeChav
Yeah thats right, i presume the fuel computer is an addition then? There is proper pipes for the job, bending it should be ok but it would be better to get the proper pipe. i bought a set but ended up not using them, probably guna sell them but i paid quite a lot for mine
gingeRS
17
Oct 2, 2015 09:42 AM
Steve Escos
Oct 1, 2015 06:57 AM
A.t.p
Sep 29, 2015 05:04 PM
