Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Fiesta durashift help!!
Old Oct 30, 2013 | 05:42 PM
Tommo55's Avatar
Tommo55
Default Fiesta durashift help!!
I have a 2004 fiesta 1.4 durashift it kept getting stuck in gear then wouldn't start, leave overnight would start up fine
Had fault codes read and found to be clutch position sensor so the tcm has been sent away for repair.
Just refitted the rebuilt unit and back bled the clutch but it doesn't want to drive
Does the clutch have to be re learned using ids??
Old Oct 30, 2013 | 05:47 PM
GVK.'s Avatar
GVK.
There is a clutch learn routine on IDS yep.
Old Oct 30, 2013 | 05:59 PM
Tommo55's Avatar
Tommo55
Is that the problem do you think as the unit has been drained down and re bled has it just lost its memory?
Old Oct 30, 2013 | 06:01 PM
GVK.'s Avatar
GVK.
It would be my first port of call yeah.
Old Oct 30, 2013 | 06:03 PM
Sticky.'s Avatar
Sticky.
It has to go on the IDS but 9 times out of 10 it's the ECU. I had the same problem with the wife's and ended up converting it to manual.
Old Oct 30, 2013 | 06:04 PM
Tommo55's Avatar
Tommo55
Cheers for that !
Is there anyone in chesterfield area with ids ??
Old Oct 30, 2013 | 06:18 PM
Tommo55's Avatar
Tommo55
Do you mean the main ecu?? As I have had the tcm refurbished
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Marv888
Sep 26, 2015 03:44 PM
