Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Fiesta Electric Widows
Old Jun 13, 2011 | 09:18 AM
sbrophy84's Avatar
sbrophy84
Default Fiesta Electric Widows
Hi, I'm sorry if this thread has already been posted, i've seen similar issues but not the same one as i'm having so here it goes!
I need help with a proper mystery thats going on with my passenger window, it opens when you use the drivers button fine but not when you use the passenger button (well very rarely!)
BUT! And here's the odd bit...
If you're opening the window via the drivers side and then you press the passenger button to do the same it interrupts the window and makes it stop!
So I know the switch is probably fine, the motor is fine and all associated gears, what I cant figure out is where the problem may lie, i figure it must be somewhere on the passengers side but I dont know
Any suggestions before I break out the big hammer????
Thanks
Steve
Old Jun 13, 2011 | 04:12 PM
Most likely the switch on the door affected is at fault.
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
