Fiesta ST This forum is for discussion of all things pertaining to the Ford Fiesta ST Range of cars.
Fiesta st omen rev limiter
Old Feb 20, 2013 | 01:19 PM
Louise holland's Avatar
Louise holland
Default Fiesta st omen rev limiter
Hi, I'm trying to fit this to my car but not sure which wire is which on the coilpack.... Any ideas?
Old Feb 21, 2013 | 10:37 PM
philg12's Avatar
philg12
Not sure mate sorry! Try phoning jam sport mate!
Have you got a decat fitted?
If not better buy one cause iv heard of cats blowing from using the rev limiter
Old Feb 22, 2013 | 05:55 AM
RichieST's Avatar
RichieST
why? What's up with the standard rev limiter? Unless you are running aftermarket management it will play havoc with it.
Old Mar 6, 2013 | 10:04 PM
AdamWhy's Avatar
AdamWhy
On the coil pack there is a block connector with 3 wires going in to it, just plugs out.
You need to splice the two blue negative wires from the Omex unit to the two outer wires on the connector.
Then you need to run the red wire to an ignition positive, and the black wire to an earth.
If you have the launch control model you will need to also run the launch wire to the button and to a negative.
Make sure its a twin coil Omex unit.
Hope this helps.
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
SMILER258
Sep 28, 2015 09:04 AM
