help please tech heads :) NEW PROBLEM
Old Aug 5, 2005 | 11:24 AM
pollocks's Avatar
pollocks
Default help please tech heads :) NEW PROBLEM
right i got a problem with my motor its a xr2i dohc 16v on a 92 k plate
the problem is i don't know if they have ignition amplifiers as i have a spark and fuel but the car won't start
its got new plugs and leads that i put on this week
spark looks a bit weak ordered a new coilpack got to pick it up tomoro
but i was wondering if theres anything i should check or nething :S am lost and have a week off and nothing to do if i aint got the car lol
Old Aug 5, 2005 | 11:26 AM
SimonT's Avatar
SimonT
you sure your getting fuel mate? is the pump priming?
Old Aug 5, 2005 | 11:33 AM
pollocks's Avatar
pollocks
yeah pumps priming on the key and u can hear it working i even made sure there was fuel in tank lol thought the gauge had fucked up lol
theres fuel getting in to the rail and pressurising and its getting into the cylinders as the plugs were wet when i checked yesterday and stunk lol
Old Aug 5, 2005 | 11:38 AM
M Brian's Avatar
M Brian
mine did this a couple of times....
I left it few days then it started....
other time I give it a bump start and it started fine and ran like normal..
check your battery voltage as I think if its even remotely weak something in the ecu stops the car.
Old Aug 5, 2005 | 11:40 AM
M Brian's Avatar
M Brian
in fact actually.....
mine did this at the same time as I got new plugs and leads!!
thats when it wouldnt go!!
sorry not much help mate but been there done that didnt find the problem but it went away anyway after bumping it.
Old Aug 5, 2005 | 11:45 AM
pollocks's Avatar
pollocks
bugger i put a new battery on this week too lol battery was wrong one i found and i had recently put sub and amp in so thought that had killed it lol
i will attempt a bump later on got to get a tow to do it lol
any other advice greatly recieved
Old Aug 5, 2005 | 11:46 AM
Graceland's Avatar
Graceland
Team HOTHOT!
you fail to mention you went thru a deep pudel and the car shit itself and shutdown
and moved to the technical section aswell
Old Aug 5, 2005 | 11:48 AM
M Brian's Avatar
M Brian
becareful when bumping it though mate as if its something more sinister than a glitch you can proper fook it.
I was 90% certain mine was just an electrical gremlin as it was running fine when I parked it on the drive before changing the stuff.
Old Aug 5, 2005 | 12:02 PM
pollocks's Avatar
pollocks
yeah myne has been running right since the puddle and it was fine till i parked it up after doing over 200miles the other night just won't work now turns over but its not firing up :S
Old Aug 5, 2005 | 01:12 PM
M Brian's Avatar
M Brian
exactly the same as mine did!!
it did it a couple of times after long journeys where it would misbehave in starting.
as another idea... crank position sensor.. if it gets wet then the chances are that it wont know where it is to fire itself up and run.
Old Aug 5, 2005 | 02:16 PM
pollocks's Avatar
pollocks
yeah graceland said this too i will order a sensor in for the garage to fit as i cba to do it lol
Old Aug 5, 2005 | 06:36 PM
sailorbob's Avatar
sailorbob
If you're getting sparks then it won't be the crank sensor.
Old Aug 6, 2005 | 12:31 PM
pollocks's Avatar
pollocks
can't get the cam sensor out now i got a spare one
Old Aug 6, 2005 | 04:41 PM
pollocks's Avatar
pollocks
right earlier on i fitted mondeo "dohc 16v" it was a 2 liter - throttle body air flow meter and coil pack it now sounds more like it wants to start but it just won't run properly
it starts but then dies it just won't rev up
Old Aug 7, 2005 | 05:01 PM
pollocks's Avatar
pollocks
now i have sorted spark and all is well on that front lol
it nows seems as theres not enough fuel getting through :S so what could it be and how do i check these things out ?? thanks in advance
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
dombanks
Sep 21, 2015 08:38 PM
routemaster
Sep 7, 2015 05:27 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
hopper350
Sep 4, 2015 12:53 AM
