T3 conversion???
Old Jan 1, 2005 | 04:06 PM
chRiSbeddall's Avatar
chRiSbeddall
Default T3 conversion???
Gday, has anyone had the t3 conversion done recently? with what injectors? what boost currently running? and the main one how much? also im looking for a set of mondeo alloys the 16" ones im currently bidding on ebay but you never know! many thanks and is there a reputable ford performance garage aroung hants? i went to the berks bull meet last wednesday very nice bunch of people and a gorgeous escos.....
Old Jan 1, 2005 | 04:15 PM
bud-weis's Avatar
bud-weis
Football Cwazy
hi , if you have no luck on here with the info on a t3 conversion, try www.fiestaturbo.com . it's quite simple from what i hear though. injectors, you should really look at getting beiges if you haven't already
http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
try these
Old Jan 1, 2005 | 05:06 PM
chRiSbeddall
nice one thanks bud i see the ebay injectors are yours!! i dont think i could do the T3 myself but can you run bieges when running standard boost etc also if i wanted to increase boost on the standard T2 is this poss with the bieges...and are they difficult to fit or do you just replace as you would a standard one,the reason is my T2 is knackered its blowing blue smoke and im wondering that i might aswell go for a T3 as it wont be that much more than a new/recon T2. many thanks
Old Jan 1, 2005 | 06:28 PM
SassyRS's Avatar
SassyRS
Little Miss...
i had my T3 conversion done about a year and a half ago my fiance did it for me, i run it on standard cooler and injectors with a 165chip at 12psi and it makes a healthy 180bhp and 191lb ft torque
as in the sig below its having a few bits done at the mo and im hoping for 220+ when its all finished
Old Jan 1, 2005 | 08:31 PM
chRiSbeddall
thanks im looking for around the same bhp just as long as its sweet and set up right,and doesnt smoke like it does at the moment,i also could do with i little paint as the filler has started to go and i want the tailgate flush...
cheeRS
Old Jan 1, 2005 | 10:33 PM
SassyRS's Avatar
SassyRS
Little Miss...
goodluck with the car mate
and happy new year
Old Jan 2, 2005 | 09:40 AM
bud-weis's Avatar
bud-weis
Football Cwazy
the beiges are just a straight swap yeah. as for the turbo, the t2 isn't great in standard form and my hybrid is probably not as good as most of the hybrid t3's but it does spin up quick and the response is very good. downside is that they cost a bomb and t3 hybrid's are cheaper. as far as i know you just need to move the rad forward and probably the battery tray may be in the way, however someone who has done the conversion will be better off advising you. if you intend to run standard boost then you won't need beiges or a hybrid but if you think you may want to increase in the future you may as well buy right the first time and get your beiges and hybrid. presuming your engine is in good nick all you'll need is a chip and you'll see 170-180bhp no probs. get it set up properly though and take it for regular checks and it should last a long time.
Old Jan 2, 2005 | 10:22 AM
SassyRS's Avatar
SassyRS
Little Miss...
For a T3 conversion you will need
Obviously a T3,
Escort turbo down pipe and manifold,
Escort turbo oil feed pipes,
You may need to move the rad forward but we just ground the actuator bracket back a bit
And a few boost hoses need to be modified slightly
its the best modification to a frst, its so worthwhile in the long run and as budweis said, its a lot cheaper than a T2 by far
Old Jan 2, 2005 | 10:56 AM
chRiSbeddall
Thanks for the advice ive been pricing up a t3 hybrid and its cheaper than a T2 how stupid is that!!!! but thanks again ill post it up when i get it done!
lateRS chris
Old Jan 3, 2005 | 10:39 AM
DUDE_SWEET_FRST's Avatar
DUDE_SWEET_FRST
the t3 is used on many turbo'd cars. so it more popular, and hence being cheaper
the t2 is used on the frst, and 5gtt i think. so a bit more scarce
you wont need 2 uprate the injectors, they will easily flow 180 bhp. so you can still run 12psi on a chip and it will be fine
and here's a guide on how 2 do it. its easy
http://www.fiestaturbo.com/content.p...rmat=showphoto
Old Jan 5, 2005 | 01:22 PM
turbomax's Avatar
turbomax
i have a renny turbo and run a t28 as the t3 was a pain to fit. does the frst use a 5 bolt hole flange on the back of the turbo or the triangle 3 bolt hole like the escort? t28 gives me 185bhp with hardly any lag off a rover 220 turbo. a 200sx,pulsar use t28 as well i dunno about the config for exhausts. all i know is the tuners try and sell my turbo as a hybrid and charge a lot more money. same as t3 hybrid for escort uses mg maestro exhaust housing and cossie 2wd front with a bit of machining to front housing. all the best max
Old Jan 5, 2005 | 04:20 PM
DUDE_SWEET_FRST
yeah, the t28 is also an upgrade option, its also a straight swap
the t2 is a 3 bolt flange, where as the escort uses 4 bolts
Old Jan 10, 2005 | 02:22 PM
matty872's Avatar
matty872
I just had a T3 conversion done on my car about 2 months ago i also had beiges+195chip and a escort pace intercooler, I was a very tight fit you do have to move the rad back and cut back the actuator bracket. I also had to hack large amounts of my front bumper out and some of the metal work behind it. I run 16psi of boost and it flyes well worth doing in all it cost £1800 thats inc labour. only do it yourself if you dont mind cutting and bending your car about/
Old Jan 10, 2005 | 05:57 PM
SassyRS's Avatar
SassyRS
Little Miss...
im lucky i never had to cut anything
Old Jan 10, 2005 | 07:48 PM
Oranoco's Avatar
Oranoco
We had loads of grief with Matty872's Everything needed to be chopped and moved and fettled. Might have had something to do with the fitment of the Escort RS Turbo Pace intercooler that we had fitted a few months earlier though.
An excellent improvement in the car though and it pulls very hard for just 16psi. And it chatters like a biatch
Old Jan 11, 2005 | 11:25 AM
chRiSbeddall
Many thanks to all who have replied, i rang various company`s and in particular i rang rad and he was really helpfull so ive decided to run with a t3 and bieges,and hopefully a double volume intercooler
cheeRS
Old Jan 11, 2005 | 12:36 PM
SassyRS's Avatar
SassyRS
Little Miss...
Good luck with the car
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
