4 pots (quick reply needed)
Old Dec 14, 2004 | 08:41 PM
redfrst's Avatar
redfrst
Default 4 pots (quick reply needed)
Hi all just a quick question i have just bought a set of 2wd Saph calipers and will be recieving them tomorrow, but what i need to know is do they fit behind escort gti 15" alloys on a Fiesta RS Turbo.
Please HELLLLPPPP!!!
pics would be brilliant
Thank you !
Old Dec 14, 2004 | 08:51 PM
mattbibs's Avatar
mattbibs
used with what? 283mm discs? if so - yes!
Old Dec 14, 2004 | 08:53 PM
redfrst's Avatar
redfrst
what discs should i use from what car
Old Dec 14, 2004 | 09:04 PM
mattbibs's Avatar
mattbibs
i thought you were doing a cossie conversion using the matching discs. those discs with calpiers will fit under those rims tho.
Old Dec 14, 2004 | 09:21 PM
redfrst's Avatar
redfrst
so if i use 2wd 4 pot calipers also use 2wd saph discs. Is this what you mean matey
Old Dec 14, 2004 | 09:28 PM
mattbibs's Avatar
mattbibs
well it sounds logical to me!
mattbibs's Avatar
mattbibs
Old Dec 14, 2004 | 09:31 PM
redfrst's Avatar
redfrst
do you know what size disc they use on the saph 2wd, and whats the biggest i can go under 15s. i thought biggest under 15s was 278mm discs
Old Dec 14, 2004 | 10:01 PM
mattbibs's Avatar
mattbibs
pretty sure cossie discs are 283mm. they will be fine. when you start using discs up close to 300mm is when you need 16's for them to fit!
Old Dec 14, 2004 | 10:03 PM
redfrst's Avatar
redfrst
Ok thanks for all you advice mattbibs was more than helpful. does anybody have any pictures of 4 pot cossie brakes behind 15's
Old Dec 17, 2004 | 09:41 PM
redfrst's Avatar
redfrst
So i take it that the 2wd cossie calipers do fit on fiesta turbo's.
As some ppl said yes they will and others said no they wont. Someone help, whats the crack
Old Dec 19, 2004 | 01:29 PM
charlieboy's Avatar
charlieboy
thats something i wouldnt mind knowing aswell i want to put 2wd 4 pots on mine aswell ive got 15'' tsw imolas on mine but should go on as 2wd cosworth wheels are 15'' anyway!
Old Dec 19, 2004 | 05:59 PM
redfrst's Avatar
redfrst
Yes im pretty sure they will go behind the 15's, but not sure if the 4 pots bold straight on or not. Any body got these brakes on there Fiesta's. Somebody must know please as im waiting to fit them if they go on.- Thanks people
Old Dec 20, 2004 | 05:51 PM
redfrst's Avatar
redfrst
Please guys really wanting to fit them now but will they just bolt on or what ?
Old Jan 6, 2005 | 03:19 PM
redfrst's Avatar
redfrst
So guys will these 2wd 4 pot calipers fit on my Fiesta RS T or not please helllllllllllp
Old Jan 6, 2005 | 05:03 PM
mattbibs's Avatar
mattbibs
i dont know for sure as mine didnt have this set up. but you could always trying taking the wheel off and putting the disc and caliper in by hand to check for clearance. might save a lot of wasted time!
Old Jan 6, 2005 | 06:02 PM
redfrst's Avatar
redfrst
ok i will try this method mate
matman
Sep 9, 2015 05:45 PM
james kiely
Aug 28, 2015 08:58 PM
Dahl88
Aug 22, 2015 08:16 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
col93saphcos
Aug 7, 2015 03:21 PM
