T3 conversion ? ?
Old Apr 11, 2006 | 10:56 PM
CJackson's Avatar
CJackson
Default T3 conversion ? ?
After some advice plz
I've just saved some cash for a new T2 hybrid but before letting it slip though my fingers is the T3 the better buy ? ? ?
What all would i need to run the T3?
Old Apr 12, 2006 | 12:57 AM
KEVFRST's Avatar
KEVFRST
many say the T3 is much better, yes it does give more power at higher revs and unlike the T2 doesnt run out of puff at 5K+
They are also cheaper to buy than a T2.
from the top of my head, and I will be corrected if Ive missed anything out, you will need the manifold from a ERST, modified downpipe, move rad forward.............
Old Apr 12, 2006 | 11:22 AM
BRAMMER's Avatar
BRAMMER
also you have to do a bit of butchering on the intercooler pipe work, but overall my T3 is the best mod so far, i would highly recommend.
Old Apr 12, 2006 | 01:58 PM
pollocks's Avatar
pollocks
plus u need the oil feed and drain pipes for the turbo as there diffrent but the connections to the block are the same as a t2 as far as i know so its just a set of erst ones
Old Apr 12, 2006 | 04:00 PM
Oranoco's Avatar
Oranoco
The oil drain pipe is different and so is the block connection. The push in block connector is about £1 but th epoxy pipe is about £30
The T3 is by far the best turbo to put on the Fiesta, I just don't get why Ford didn't do it in th efirst place.
If you have half an ounce of DIY talent you will be able to do the conversion. The toughest bit I dealt with was mating an Escort doenpipe to my FRST system. My bro soon sorted that out with some spare stainless and his welder
Old Apr 12, 2006 | 06:43 PM
CJackson's Avatar
CJackson
Cheers for the info it's gave me a much better idea
Is there any body work need's changed ie front panel or bumper cause would rather stay away from that think i'll be sacking the T2
Old Apr 12, 2006 | 07:02 PM
Oranoco's Avatar
Oranoco
I cut the front panel to allow me to move the rad and fan forward. Took 5 mins with an anglegrinder
Old Apr 12, 2006 | 07:09 PM
CJackson's Avatar
CJackson
could maybe live with that any more pic's would be great
Can u still have the fillter sitting at the drivers side? ?
Old Apr 12, 2006 | 07:17 PM
Oranoco's Avatar
Oranoco
Nope you need to relocate it under the battery.
The worst bit was modding the boost hose from the turbo to intercooler. That was bitch but got there in the end
Old Apr 12, 2006 | 07:31 PM
CJackson's Avatar
CJackson
Night mare and i'v just finished making a head light pod for the driver's side Hense why i asked
Old Apr 12, 2006 | 07:43 PM
Oranoco's Avatar
Oranoco
Ah well. Call it practice and do one one for the passenger side. You should be good at it now
Old Apr 12, 2006 | 07:55 PM
CJackson's Avatar
CJackson
suppose thats one way of looking at it ha ha
cheers for all the info Time 2 do some head scratching and choose which one 2 go with Hmmm!
Old Apr 12, 2006 | 08:07 PM
fezzanut's Avatar
fezzanut
i wanna go to a t3 but im worried about moving the rad cos ive had to move it back for my pace intercooler which overlaps the rad and i cant think of a way round it
Old Apr 13, 2006 | 11:45 AM
Oranoco's Avatar
Oranoco
My bro's FRST has my old Pace intercooler on it and we still managed to T3 that. It just means a bit more trimming of the bumper and bottom panel
Old Apr 13, 2006 | 01:24 PM
stevos1's Avatar
stevos1
iv got a t3 going on mine just waiting for the downpipe to be welded
Old Apr 13, 2006 | 07:09 PM
Shell's Avatar
Shell
Mine has a T3 on it and when i bought it on the first night that hose popped off, looked at it the next day and whoever had made it had made it out of two jubilee clips and 3 bits of hose
Then the actuator put a hole in the rad so i had to get that re-cored...
so deffinatly move the rad forward!!
Old Apr 14, 2006 | 10:08 AM
Oranoco's Avatar
Oranoco
You can't not move the rad or as you say Shell you will put a hole in it. I just droped the bottom locating lugs out of their positions towards the bumper and used the original top fixings and have about 25mm of clearance now. Even with very tired engine mounts I have no probs.
Old Apr 14, 2006 | 12:13 PM
Shell's Avatar
Shell
Wish someone would have told the guy that fitted the T3 to mine that!! Cost me £200 to have it fixed and moved includng labour!!
Old Apr 15, 2006 | 01:43 PM
SassyRS's Avatar
SassyRS
Little Miss...
we only had to move the rad forward slighty the rest we ground from the actuator bracket
Old Apr 15, 2006 | 03:34 PM
BRAMMER's Avatar
BRAMMER
One bit of advice get a small -31 actuator not like my flaming big space ship style thing
Old Apr 18, 2006 | 12:38 PM
pollocks's Avatar
pollocks
the downpipe has to be off an escort rs turbo then and not off a cossie i take it
Old Apr 18, 2006 | 12:50 PM
SassyRS's Avatar
SassyRS
Little Miss...
escort rs turbo
Old Apr 18, 2006 | 01:09 PM
pollocks's Avatar
pollocks
cool neone got one for sale lol
Old Apr 18, 2006 | 01:31 PM
SassyRS's Avatar
SassyRS
Little Miss...
put an add up in parts wanted
Old Apr 18, 2006 | 01:57 PM
pollocks's Avatar
pollocks
last question before i go put up my parts wanted lol
would a standard downpipe be orite or do u need to have a stainless one ??
Old Apr 18, 2006 | 02:26 PM
SassyRS's Avatar
SassyRS
Little Miss...
yes a standard one would be fine
SassyRS's Avatar
SassyRS
Little Miss...
as long as its an Escort one
Old Apr 18, 2006 | 02:37 PM
BRAMMER's Avatar
BRAMMER
I got one made at a powerflow centre cost £40 fitted which i didn't think was too bad and its stainless
Old Apr 18, 2006 | 03:01 PM
pollocks's Avatar
pollocks
will have to have a look into going to powerflow
have got my eye on a standard one at the mo
Old Apr 19, 2006 | 03:26 PM
turtleturbo's Avatar
turtleturbo
Hi,
I've also found myself a T3 I probily start this weekend whit it. But one Quesion did you all connect the water cooling? And I now am running on standard T2 whit 14 PSI and 165 chip. If i 'va fitted the T3 wich boost can I run whit the 165 chip?
Cheers.
Old Apr 19, 2006 | 03:43 PM
Oranoco's Avatar
Oranoco
I retained my water cooling by using th eEscort RST top rad hose and extending the return pipe to the rad. I'm using a 195 chip on mine with no problems but I would recomend speaking to your local friendly tuner
Old Apr 19, 2006 | 05:21 PM
SassyRS's Avatar
SassyRS
Little Miss...
nope mines not water cooled
Old Apr 19, 2006 | 05:33 PM
pollocks's Avatar
pollocks
nor is mine and all series one rs turbo escorts left the factory with no water cooling
Old Apr 20, 2006 | 08:06 AM
turtleturbo
Ok thnx. Think that i will not connect the water cooling too. It is running hot already whit the T2 if I step on the gas. Do you all run whit a 195 or cutom made chip and on whitch boost? And did you replace the fuel pump as well for a stronger one?
Old Apr 20, 2006 | 10:46 AM
BRAMMER's Avatar
BRAMMER
You can run with the 165bhp chip no probs just get the boost set at 14psi on the the T3 actuator,
I run standard chip on mine with water but if i were to chip it i would blank the water up to keep the engine temperature down,
yes down the water that runs through the turbo goes back through the engine cycle hence higher engine temperatures,
The downside to NON-water cooled is that you have to let the turbo wind down correctly i would advice a turbo timer for this.
Old Apr 20, 2006 | 12:41 PM
turtleturbo
Ow ok thnx, I thought that it could maybe be a difference 14 psi on T2 and T3 because the T3 is bigger. So thought that i have to run less boost whit the T3.
The downside of it is ok, I'm used to it. I always let the car cool down and warm up.
Old Apr 20, 2006 | 05:13 PM
pollocks's Avatar
pollocks
yeah the chip will be ok for it as in it won't boost cut but u do need to get it properly set p by a tuner as with every mod really
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
