Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Focus ST170 conversion into mk6 escort van
Old Mar 2, 2021 | 09:17 AM
Bennyboy888365's Avatar
Bennyboy888365
Default Focus ST170 conversion into mk6 escort van
Hi everyone,
I'm in the process of swapping out my old non turbo diesel engine in my mk6 escort van thinking that the st170 engine and setup would be a good fit but I've heard that there could be some ECU issues??
Any advice on this or anything to do with the conversion itself including any other parts needed or that I can use like suspension etc would be hugely appreciated.
Old Mar 3, 2021 | 09:24 AM
STeve's Avatar
Super Moderator
used to sell a lot of st170 engines complete with ecu's to folk fitting them into 1.8d vans none mentioned anything awkward about it
Old Jul 1, 2021 | 09:04 AM
bgenie's Avatar
bgenie
5 Year Member
I have been looking into this also for my Mk6 although I have the TD which I love in normal driving but on the dual carriageway its like "get it out of here!!!!" The ST170 is a Zetec derived engine I believe and from what I am hearing if you can use the donor car loom and other parts from a standard Mk6 (think flywheel and sump) then it will be a less complicated modification.
Of course I am unsure of the engine and gearbox mounts will line up so you may need to get new mounting plates and have an old Mk6 mount adapted to fit the new plates/mounts.
As for the ECU several I have seen use throttle bodies but if you have the full loom from the ST170 why not use that. I think you may find it difficult to get the fuel tank for the van now as the petrol pump is different to the diesel and there are not many of the petrol variants around nowadays. You could modify the diesel fuel tank tho with much caution!!!!
I came across this service on eBay for original car looms to be modified to run the ST170 if you are unsure how to do this yourself.
Sharpy609
Dec 24, 2013 07:51 PM
Sharpy609
Dec 21, 2013 02:18 PM
Munchkin6288
16
Nov 7, 2013 06:46 AM
A11COS
Jul 16, 2012 06:50 PM
hainesy555
Mar 27, 2011 12:13 AM
