Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
dizzzy conversion ---gearbox probs !
Old Apr 14, 2005 | 08:12 AM
tizer's Avatar
tizer
Default dizzzy conversion ---gearbox probs !
from coils-dizzy--
do i need the sensor on the flywheel ???
and can i put a s1 turbo box in ????
Old Apr 14, 2005 | 10:09 AM
andyt's Avatar
andyt
You dont need the senser if your running on a dizzy mate and the S1 box will fit
Old Apr 14, 2005 | 04:31 PM
GraphiteGray's Avatar
GraphiteGray
~If its running a dizzy and coil it wont need the sensor, you can fit a S1 gearbox but the Twin coil setup is better
Old Apr 15, 2005 | 08:03 AM
tizer's Avatar
tizer
why the coils, ive heard there prone to problems
whats the advantages ???
Old Apr 15, 2005 | 09:27 AM
It's Czech Mate's Avatar
It's Czech Mate
you get to run the proper ignition curve with the coils
Old Apr 15, 2005 | 10:10 AM
tizer's Avatar
tizer
how hard to convert back to coils, what do i hav to change ??? the wiring is a bit confusing at the mo' coz it came to me with the dizzy
Old Apr 15, 2005 | 10:11 AM
tizer's Avatar
tizer
GraphiteGray,
Old Apr 15, 2005 | 11:48 AM
GraphiteGray
Yes it is something to do with having a better ignition curve, there was a big discussion on the advantages on the RSBB about this but i cant find it
the only problem is the availability of parts like the twin coils and the gearbox sensor (although there have been discussions about remaking these)
If you have the gearbox sensor and the wiring (i assume you still have the ecu under the dash? you need to check that ) all you need is the twin coils and the mounting bracket and someone who wire them back up, the common thing on the rsi when people convert to a dizzy is to just chop the coil wires and reconnect them to the dizzy and coil wires.
It is worth doing, and you will notice the difference
Old Apr 15, 2005 | 12:34 PM
tizer's Avatar
tizer
still gt the black ecu, and i dnt kno if the original wiring is still there, got the sensor still tho, so if anyone needs one its 4sale coz il hav 2 shortly !
any offers ?
Old Apr 16, 2005 | 12:30 AM
GraphiteGray
Is the ECU still under the dash? if so is there a plug and wires connected to it? i would think you still have the original wiring, check that the sensor lead is still connected (just follow it through to the inside) you may still have the original wiring its probrably just been bodged to run the dizzy and coil
Old Jul 15, 2005 | 08:19 PM
Martein's Avatar
Martein
So you are runninmg with a dizzy and coil ?
What is the ignition time on that ?? As I can't find the right time to set anywhere...
I got an XR3i (Lucas) dizzy wth vacuum advance, but I can't get the thing rnning right.... (it's now on 12 deg.)
Thanks !
Martein
Old Jul 17, 2005 | 12:41 PM
Red16's Avatar
Red16
tizer, i got a pair of coils in my garage that i wont be needing if youre interested in them and also a loom
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
