Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Starter Motor Issues-HELP-Darlo
Old Sep 2, 2012 | 10:48 AM
staffychance's Avatar
staffychance
Default Starter Motor Issues-HELP-Darlo
We have a wired problem.
Car was not charging, so we removed alternator for a spare, no battery light on dash, got told to check little green wire from alternator, it was broken re joined an the battery light worked but stayed on so it seemed the alternator was not charging, swapped alternator back.
Battery light came on and went off as it should, but the starter motor was noisy as hell (never had an issue in the past), the starter is turning the car but seems to keep running not releasing, so we swapped for another and same story (the only thing was we were not 100% on the condition of these starters in the first place), we just bough the weekend before a mk6 gti for spares which ran ok, so we removed the starter from this.
Started it yesterday all seemed fine, but noticed the starter was still spinning and it started to smell then the car just cut out, straight out, any ideas??
We were sure all the starters were fine as we tested before fitting with batt charger (now the dont even move, they just buzz). Something is causing them to keep on running and burning themselves out.
The only other thing is we have an FIA cut off switch but the car does start and the switch kill everything as its supposed to, The starter live goes through the switch, but the car starts ok so ive sort of cancelled the switch out.
Any help/advice welcome
Old Sep 2, 2012 | 10:55 AM
Do you still use an ignition key.The switch on the back of the barrel could be faulty causing the starter motor to stay engaged.
Old Sep 2, 2012 | 05:34 PM
staffychance
Hi Glen
Yes we are still using the key.
Old Sep 3, 2012 | 07:26 PM
staffychance
Does anyone have a pic of mk6 escort starter wiring please.
Old Sep 3, 2012 | 07:53 PM
foci's Avatar
foci
Well there's a live that goes from the starter to the alternator. Have you wired it correctly?
Old Sep 4, 2012 | 10:04 AM
staffychance
To be honest Im not sure anymore, Basically i removed the starter and put it back as was, and ive had problems, I must have changed starter motors 20 times before on various cars, i cannot believe the chew, to be honest im starting to think i was wrong originally and i have trusted it was correct from the start.
I have
Big Wire from Alternator to Starter connection
Green Wire from Alternator to small starter Connection
From the Battery (via cut off switch) is a Big Red wire that is connected to a FORD Plastic Shroud
And a black earth lead to the gearbox housing.
Old Sep 4, 2012 | 07:05 PM
staffychance
OMG Its done
Took live from alternator and moved it to the same connector as the battery live and it works fine, im not gonna make excuses but i have some ha ha......im a dick
Cheers for the help and advice guys.
bobsworth
77
Mar 24, 2016 09:30 PM
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
