Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
rs2000 help. hesitation when warm
Old Mar 5, 2009 | 11:37 AM
srlew's Avatar
srlew
PRO BISCUIT DUNKER
Default rs2000 help. hesitation when warm
right then my brothers mk5 rs2000 when warm runs bit rough, feels like something to do with plugs. bit of hesitation, got new plugs and 2new coils on, but when it warms up it still does it
i drove it earlier it warmed up etc, turned it off tried starting it again and it wouldnt start was just turning over, asked a mate, he said could be temrature switch, as is giveing it to much fuel etc.
so need to know what one im ordering etc, is there only one temp switch? and where is it located?? pics would be good cheers all
anything else to try to cure this??
cheers lew
Old Mar 14, 2009 | 12:10 PM
derekd's Avatar
derekd
check these tps,lambda`s,check the coil packs loom**,fuel filter and clean the iscv all of these can cause this problem mate just rule them out one after the other good luck
Old Mar 14, 2009 | 08:47 PM
andy-rs's Avatar
andy-rs
coil pack loom caused similar problems on my last 2000! tend to go where the loom bends tightly into the rocker cover under the plug cover!
Old Mar 16, 2009 | 11:22 PM
srlew's Avatar
srlew
PRO BISCUIT DUNKER
ah right cheers boys! will check them out!
need it sorting
muzzman1
Sep 30, 2015 08:59 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
pabloXR
Sep 21, 2015 12:42 PM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
