Csoworth Engine Mounts
Old Apr 7, 2020 | 12:26 PM
Snags's Avatar
Snags
Default Csoworth Engine Mounts
Hi, I am a returner to PF and have a Westfield kit car with a Cosworth YB fitted.
After considerable adjustments to fit into chassis I have at last got a usable motor, unfortunately the build has taken longer than expected and some of the wear items have seen better days.
After removing the engine to renew the crank and sump seals I have found that the engine mounts are past their sell by date and 1 has virtually collapsed.
As OEM units are not available what is the best option for replacement, I am still running T3 turbo with Omex 600 electrics producing circa 300lbsft torque and not expecting to tune much further as already interesting getting power down in a set up weighing 650kg.
Old Apr 7, 2020 | 01:01 PM
christos's Avatar
christos
10 Year Member
I use Collins engine mounts in my 4x4 sapphire and they are awesome! I think they are better than vibratechnics
Regards
Old Apr 7, 2020 | 01:53 PM
Snags's Avatar
Snags
Thanks, I was worried that these types would be too hard as I don't expect much in the way of track use so looking for reasonable performance.
Certainly Collins look well made so will give a try.
Old Apr 7, 2020 | 02:51 PM
dan le moignan's Avatar
dan le moignan
After a bit of research I went with the Collins ones as meant to transmit less vibration.
On the road not noticed any difference over standard
THE RADMAN
Oct 22, 2010 01:04 PM
warleydaddy
Fiesta RS1800/RS Turbo
Feb 20, 2008 10:48 PM
slowpoke
22
Jul 11, 2006 10:18 PM
cossie_baz
May 27, 2005 07:31 PM
