How do you get carpets clean?
Old May 13, 2009 | 11:00 AM
yappstar's Avatar
yappstar
Default How do you get carpets clean?
I mean proper clean, Ive hoovered mine, and given it a light once over with shampoo, its clean, but it hasn't brought it back to the standard I want
I want it looking as new as possible, any tips or products?
Ta
Old May 13, 2009 | 11:15 AM
Ed1's Avatar
Ed1
I was thinking the same thing not so long ago, I was going to hire one of those rug doctor things, i recon they would bring them up a treat!
Old May 13, 2009 | 11:16 AM
rs_jim's Avatar
rs_jim
i use a wet vax,im pretty sure you can rent them or some one on here said you can. or take the carpet out put interior shampoo on it leave it couple of minutes and jet wash not sure if that can shred the carpet..so dont do it and just wait and see what others say lol
Old May 14, 2009 | 07:50 PM
Polished Bliss's Avatar
Polished Bliss
Official Car Care Sponsor
To do it properly, you really need to use an extractor. Our method would be to thoroughly wet shampoo the carpet using a products like Autosmart Bio-Brisk, working the shampoo in gently using an interior carpet brush (Meguiars All Surface Interior brush is ideal). By foaming up the shampoo you can easily lift deep seated grime. The next step is the important bit - you need to suck up the foam and as much moisture as possible using an extractor (also known as a wet n dry vacuum cleaner). If you fail to do this and leave the carpets overly wet, then you risk mildew setting in. If you don't have the right gear, it would be best to pay a good valeter/detailer to do this job for you. Other options include buying a cheap extractor, or hiring one, as suggested above.
Old May 17, 2009 | 06:10 PM
yappstar's Avatar
yappstar
Thanks again for the info guys
the seats are out at the minute so I might whip the carpet out and have a bash at it
Old May 18, 2009 | 08:37 AM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
If its possible (like you said above) to get the carpet out, its so much easier, because most Ford carpet has a tough backing, so you can go at it quite hard with the cleaning solutions, without fear of saturating the sound proofing underneath it.
In the past i have pressure washed a S2 carpet (after a healthy scrubbing of Autosmart Brisk) with no ill effects, just make sure you have somewhere to hang it to dry properly.
It also gives you the chance to clean the floorpans out and check for rot etc etc etc.
Old May 18, 2009 | 06:52 PM
yappstar's Avatar
yappstar
Good plan, cheers.
This one is on an R33 GTR though not the ford
hopefully no rot this time
chowfornow
14
Jan 5, 2019 09:01 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
