Porter cable
Old Jan 2, 2008 | 07:43 AM
boost mad's Avatar
boost mad
Default Porter cable
Got a porter cable polisher for my birthday. noticed it is a 2 pin dual insulated jobby. what transformer things do you lot use ?
cheers
Old Jan 3, 2008 | 07:15 AM
ozzy's Avatar
ozzy
You might want to look here.....
http://www.detailingworld.co.uk/foru...ead.php?t=4717
Old Jan 3, 2008 | 07:48 AM
boost mad's Avatar
boost mad
cheers for that. i no i need a 110v transformer, but didnt want to change the plug end of the PC from a 110 us to a 110 uk type as chopping the end off would screw the warrenty . did find somewhere that does a cable ( like an extension ) that converts it which would save the cutting off the end but he is out of stock and has been for a while i cant find one anywhere else. hope that makes sence
Old Jan 3, 2008 | 10:56 AM
coldflame90's Avatar
coldflame90
if you go on
http://www.detailingworld.co.uk/foru...ad.php?t=18554
shows an alternative way of dfoing the rewire insted of chopping the plug off so the warrenty isnt screwed up
Old Jan 3, 2008 | 02:22 PM
boost mad's Avatar
boost mad
Originally Posted by coldflame90
if you go on
Old Jan 4, 2008 | 12:09 AM
ozzy's Avatar
ozzy
I did not click the link above, but this is the plug you can use to convert it ...
http://cpc.farnell.com/jsp/Electrica...sp?sku=PL06744
Old Jan 4, 2008 | 11:31 AM
oilcosworth's Avatar
oilcosworth
Default Re: Porter cable
cheers
Hi mate i have just bought a udm and it also has the 2 pin plug so i
bought this its from a shop called maplins dont no if they have them
down ur way it was Ł20 and its only small heres a pic mate hope it helps
Old Jan 4, 2008 | 07:13 PM
lockpaul's Avatar
lockpaul
that transformer wont last long as you need 750va + to run the udm
and yes the ablove link is what you need to keep warenty its what i have
i just got a normal 110v extension lean and chopped the end what conects to udm and replaced with a 240v end if that makes sense
Old Jan 4, 2008 | 07:32 PM
oilcosworth
That funny as a mate runs is pc with
the same and hes had that over a year
but you are right ive tryed it and doesnt seem
to get hot and runs ok ,like most people only
doin my own car its not bein used for a full
time job lol
Old Jan 4, 2008 | 11:11 PM
lockpaul's Avatar
lockpaul
iv been told there usless as i was going to get one as it was cheap and i like cheap
i needed more powerfull one anyway as it will be used for work so i cant complain
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
mk1turboestate
Dec 2, 2015 08:31 PM
muz
Sep 30, 2015 08:29 AM
Flatlinedan
Sep 18, 2015 12:41 PM
Bransby
Sep 14, 2015 08:54 PM
