Replacement for autoglym(CALLING GAZ7)
Old Jul 5, 2007 | 10:06 AM
Turbo Pez's Avatar
Turbo Pez
Default Replacement for autoglym(CALLING GAZ7)
Right run out of autoglym super polish, and wanted to try something diff, heard good stuff bout Meguairs tech wax, can you used this the same a autoglym just 1 stage etc and its it beta?
Also while im here is there a bug remover you can spray on say a couple of mins before you wash you car, and then wash it of when you wash the car?
Old Jul 5, 2007 | 10:12 AM
KSA-Cossie's Avatar
KSA-Cossie
Get some poorboys m8 you won't look back .
Old Jul 5, 2007 | 02:08 PM
Turbo Pez's Avatar
Turbo Pez
Is it as easy to use as autogylm, i will be hand buffing it!
Old Jul 5, 2007 | 04:22 PM
justin j's Avatar
justin j
very easy to use m8 give, gaz7 a shout he will sort you send him a pm
Old Jul 5, 2007 | 04:31 PM
KSA-Cossie's Avatar
KSA-Cossie
Dead easy m8.
Old Jul 5, 2007 | 05:57 PM
Turbo Pez's Avatar
Turbo Pez
GAZ7 what poorboys you recommend? Cars pepper red! Need something easy to use as autogylm polish as im lazy
Old Jul 8, 2007 | 02:55 PM
scortgti's Avatar
scortgti
i find autogylm quite hard to use cause you get so much dust off it.
Old Jul 10, 2007 | 06:54 PM
justin j's Avatar
justin j
you mite be putting to much on if you are getting dust m8 the poorboys stuff you put a thin layer on thinner the better so it last for ages
Old Jul 10, 2007 | 11:32 PM
Gaz7's Avatar
Gaz7
Hi mate,
Spray on Poorboy's Bug Squash a couple of mins before you wash the car, then wash as normal - job done Polish pepper red with either Polish with Carnauba Blue, or the all in one Polish with Sealant. Either will look great (the AIO is good if you don't intend to do a dedicated glaze/sealant stage) and both are easy to use.
Gareth
Old Jul 11, 2007 | 12:08 PM
Turbo Pez's Avatar
Turbo Pez
Originally Posted by Gaz7
Hi mate,
Gareth
Cheers geezer, you can get them of them of that car wash site cant ya? Whats the all in one polish called?!
Old Jul 11, 2007 | 12:18 PM
Turbo Pez's Avatar
Turbo Pez
Went on cleanyourcar.co.uk, is the all in 1 polish called Chemical Guys - All-In-One Polish, cant find the bug spray on there either? Mite just be me tho
Fudgey
21
Sep 30, 2015 06:19 PM
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
