Cleaning Recaro's
Old Jan 16, 2007 | 12:41 PM
Brian's Avatar
Brian
Default Cleaning Recaro's
What stuff is good to use to clean my Recaro's in my Escort Rs Turbo??
Brian
Old Jan 23, 2007 | 09:55 PM
timturbo's Avatar
timturbo
ive heard you can wash recaros in washing machine and they come out mint but would no how do it read it in fast ford
Old Jan 23, 2007 | 11:39 PM
Gaz7's Avatar
Gaz7
Removing the seats and wet-vaccing them is effective if you can go this route; otherwise, it depends on how dirty they are. If they're not too bad, you can get effective results from various cleaners
Gareth
Old Jan 24, 2007 | 11:17 PM
Brian's Avatar
Brian
They aint to bad just thought i would give them a clean
Brian
Old Jan 26, 2007 | 12:27 AM
Gaz7's Avatar
Gaz7
Try some ClearKote Extra Duty in that case - spray on, work foam in, vac the seats once dry
Gareth
Old Jan 29, 2007 | 08:26 PM
boybiffa's Avatar
boybiffa
go to sainsburys and look out for something called active naturals its a pale green in the toiletries section if you get some white dish clothes spray a little on the patch rub in any motion just keep rubing for about 5 mins this works with carpet the same! afetr rubbing for a while leave for 20-30 mins for it to dry it will be as god as new!!
rob
Old May 12, 2007 | 06:41 PM
RSricRS's Avatar
RSricRS
Long live the ford RS'S
Take them to bits and put them in the washing machine!!
Old Dec 29, 2007 | 11:58 AM
moesin2005's Avatar
moesin2005
took mine out carpet and all and blasted them with a hot pressure washer they came out mint u can see all the left overs from previous valets come out as well
Old Dec 29, 2007 | 12:04 PM
gkandr4ch's Avatar
gkandr4ch
I took my last set apart and stuck them in the washing machine. But what I found was really good at getting the stains off was petrol. They came up MINT.
chowfornow
14
Jan 5, 2019 09:01 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
Adam Graham
Sep 6, 2015 06:04 AM
