Quick external/usb HDD question.....
Old Apr 18, 2006 | 09:49 PM
Thrush's Avatar
Thrush
Irritating c........
Default Quick external/usb HDD question.....
Think it's about time I got a back up drive, to back up files. MP3's, pics etc from my household PC's, just in case a disk fails or OS corrupts, etc...
Mate of mine has a spare 60gb drive (normal 3.5" IDE internal drive) which he might let me have for £30....
Whats a good USB 2.0 enclosure to fit it into?
Do They need to be powered? (guessing they do)
Do they need to have a fan inside the case?
What sort of price should I be paying for an enclosure, with PSU, cable etc?
Can I buy one on ebay? Or is that a no no (cue Dan )
Old Apr 18, 2006 | 09:55 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Thrush,
3.5" will need external power, only laptop drives (2.5") can be powered off the USB port and even then, I've seen 80Gb ones not power up properly.
But, £30 for a 60Gb drive
You can get a hell of a lot more for that money, £60/70 will get you close to 250/300Gb iirc
And what good is a 60Gb when you have 300Gb of porn to backup You're going to spend months trying to figure out which movies you REALLY want to keep.
This one, no that one, ah, but this one's quite cool, etc............
Try Dabs or eBuyer for a case, I can't think of anything to look for specifically
Old Apr 18, 2006 | 10:08 PM
Thrush's Avatar
Thrush
Holy fook, you're right!?!?!?! I just looked on Ebuyer - a 120gb drive costs £40-odd
Fooking prices have come down since I last bought a drive - I paid £30 for my 80gb drive last year!!!!
The slave drive in my PC is an 80gb drive, but I am only using 25gb on it so far, my main drive is using 44gb (out of 60) but then, I do have a 60% back up of my slave drive on there also...
My family pc has a 40gb drive and is currently at abotu 30gb used, but I suppose when you strip that down to mp3's, doc's, files and pics, it's probably only 20gb....
so 20+25+10 = 55gb roughly that needs to be backed up, so might be better off with an 80gb drive, possibly a 100gb drive....
Thing is, since it won't be used a lot, I don't wanna pay a premium for it (plus, I am poor )
Ideally, if I could get say, 80 or 100gb drive plus an enclosure and relevent PSU's, cables etc for abotu £50 that'd be about right....
Old Apr 19, 2006 | 09:16 AM
DanRSturbo's Avatar
DanRSturbo
You may as well stick 2 larger drives in there and backup what's required. I have 4 hard drives in my system at the mo, 2 x 120's and 2 x 160's. I also have 2 spare 40 gig drives, and 2 spare 60 gig drives. I did run 6 drives before but moved to bigger ones for the storage purposes. I'm next looking at a bigger case with lot's of drive bays and filling it with hard drives
Old Apr 19, 2006 | 04:43 PM
Thrush's Avatar
Thrush
Dan - my PC (and my downstairs PC) both run on standard IDE cables, and only have the one slave connector, and I don't know how you run more than two HDD's in a PC anyway lol....
But I use my secondary/slave drive for all my MP3's, vids, movies, pics etc, and the main drive (C for the OS, and all the programmes and system files...
But, if my slave drive goes tits up and fails, I will lose all my shit - not good!
My downstairs PC only has one drive, and my old dear probably ain't interested in sticking another drive in it (she don't understand all this PC malarky) The main drive is a 40gb drive, and I checked it last night - it's only using 15.5gb anyway...
So all I was thinking was getting a largish drive to whack in a USB enclosure, back up what is needed off both PC's, and then just keep it in a draw - as in it won't be used unless I need to recover the date from a damaged drive etc...
How long can you keep data on a HDD without it being plugged into a PSU?
Old Apr 19, 2006 | 04:55 PM
frog's Avatar
frog
For ever Well certainly longer than you'd ever want to
Old Apr 19, 2006 | 06:22 PM
Thrush's Avatar
Thrush
Sorted then Wasn't exactly sure if it needed power the majority of the time or not
Just gotta decide how much space I want/need..... With 120gb drives costing £40-£45 now a 60gb drives gotta be worth £20 right? So could I get a fully set up enclosure, with plug'n'play USB 2.0, psu, cables etc, ready to rock for less than £30? I know I can from ebay of course, just wondered about shops....
Old Apr 19, 2006 | 06:28 PM
Thrush's Avatar
Thrush
Like this?
http://cgi.ebay.co.uk/3-5-HDD-HARD-D...QQcmdZViewItem
Just add a normal IDE drive right?
Old Apr 19, 2006 | 07:26 PM
frog's Avatar
frog
The eBay item would be perfect yes
Old Apr 19, 2006 | 09:16 PM
Thrush's Avatar
Thrush
Good price?
Old Apr 19, 2006 | 09:19 PM
frog's Avatar
frog
Depends how much the bidding ends at
Have a look on ebuyer or dabs.com for similar items and see how far you should be bidding for one
£9.99 for postage is a bit steep though
Old Apr 19, 2006 | 09:32 PM
Thrush's Avatar
Thrush
Yeah, but cheaper than getting one from China
I looked on Ebuyer, but they NEVER make it easy to find what it is you are looking for
Old Apr 20, 2006 | 08:13 AM
DanRSturbo's Avatar
DanRSturbo
I've got a PCI IDE controller, which has 2 x IDE ports on it, allowing 2 drives on each .
You can run 4 drives off the motherboard, so, 1 master, slave on IDE 1, 1 x DVD burner and another hard drive on ide 2 would give you 3. One for Windows, and 2 for sotrage.
Or, maybe something like this ?
http://www.ebuyer.com/customer/produ...duct_uid=80599
Old Apr 20, 2006 | 05:39 PM
Thrush's Avatar
Thrush
Dan - did you mean you can run THREE drives of the mobo, as your next sentence only lists three, not four....
I get what you are saying about the PCI IDE controller tho All makes sense now
Old May 9, 2006 | 07:13 PM
Thrush's Avatar
Thrush
Well, my friend at work just gave me his 60gb drive
So all I need now is the enclosure, PSU, and cables, and am bidding on one on ebay...
Last question - would I be right in guessing that even with USB 2.0, file transfer from one internal IDE drive to the USB drive is gonna be slower than internal IDE to internal IDE (slave)? If so, how much slower are we talking?
Old May 9, 2006 | 11:16 PM
DanRSturbo's Avatar
DanRSturbo
Depends what you are transferring m8 really
Old May 10, 2006 | 06:44 PM
Thrush's Avatar
Thrush
Typical stuff really : music, video clips, word docs, pics, etc...
Old May 19, 2006 | 12:06 PM
Thrush's Avatar
Thrush
Yay! Me enclosure arrived today! Just put it together and plugged it in - seems to work fine!
Transfer rate after one test seems to be okay. I copied a folder full of Prgramme and EXE files. 44 objects (mix of installers, .EXE's and RAR/ZIP files) total 369mb and that transferred in about 30 secs.
Anyone tell me what speed that transfer rate is please?
Old May 19, 2006 | 04:27 PM
frog's Avatar
frog
369/30 = 12.3 mb / sec
Old May 19, 2006 | 06:00 PM
Thrush's Avatar
Thrush
Is that good then? Is that about right for USB 2.0?
(I don't actually know if my PC has USB 2.0 )
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
