Help with Java
Old Feb 25, 2006 | 07:36 PM
M.A.D.RST's Avatar
M.A.D.RST
Default Help with Java
On my control panel, i go to internet options, then advanced and scroll down to Java Sun and along side this in brackets it says 'requires restart'.
Does this mean its not working correctly, and how do i restart it if it needs to be?
Thanks.
Old Feb 25, 2006 | 07:42 PM
T38Mat's Avatar
T38Mat
It means your pc needs a reboot, however I guess you have tried that already! It may just be "stuck" uninstall your current version and then go to java site again and download the latest version, try that.
good luck!
Mat
Old Feb 25, 2006 | 07:47 PM
M.A.D.RST's Avatar
M.A.D.RST
Thanks mat, ill try that now and let you know the outcome
Old Feb 25, 2006 | 11:20 PM
Thrush's Avatar
Thrush
Irritating c........
No, what it means is, if you tick/untick that particular box, then you need to restart the PC for the changes to take effect!
I assume you mean this?
Old Feb 26, 2006 | 11:39 AM
M.A.D.RST's Avatar
M.A.D.RST
Yes thats it
Old Feb 26, 2006 | 12:00 PM
Thrush's Avatar
Thrush
The "require restart" is only if you tick or untick that box - the changes won't take effect untill you restart the computer, as it has to load from start up
Old Feb 26, 2006 | 08:03 PM
M.A.D.RST's Avatar
M.A.D.RST
It still says 'requires restart'?
Old Feb 27, 2006 | 09:30 AM
DanRSturbo's Avatar
DanRSturbo
Is that after applying the update ?
Old Feb 27, 2006 | 08:56 PM
Thrush's Avatar
Thrush
It will always say requires restart - thats additional information.
If that box is unticked and you tick it, you have to restart the PC in order for the changes to take place.
Likewise, if the box is ticked and you untick it, you have to restart the PC in order for the changes to take place.
It doesn't mean it's not working cos it says requires restart..... it means "this option requires you to restart your PC if you want to apply/unapply the setting"
Follow me?
Old Mar 3, 2006 | 05:13 PM
M.A.D.RST's Avatar
M.A.D.RST
Thanks mate, i get ya
Joe91
Dec 16, 2012 02:09 PM
All4it
Jan 5, 2011 11:15 AM
~nomad~
Ford Classics & Vintage
Dec 8, 2008 08:19 PM
mad max
Computers, Consoles and I.T.
Oct 29, 2006 01:27 PM
